Question about Acer Ferrari 3200 Notebook
Change the HD in the Acer Ferrari 3200
Do you think I can stand the sostitution by myself or I need to take the laptop to Acer assistance? Probably could be enough having a technical description of the PC with instructions about how to open it.
Thanks a lot for the support.
  • cepranoide Jun 16, 2008
    Thanks a lot! I was able to remove the HD
Uslaly u fold sceen open all way pop top panel off then remove kb then top then dvd rom drive
Posted on Jun 16, 2008
Hello, how can i get my Acer Ferrari 3200 to see the full 320 Gig Hard drive, at the moment it will only see 128 gigs.
Open your partition manager. Check if there are partitions other than the 128Gb detected. If there are others, you can create a new partition for those unpartitioned space
Apr 27, 2011 | Acer Ferrari 3200 Notebook
How to connect acer ferrari one 200 netbook to tv through VGA TO VGA CABLE ??
i have acer ferrari 200series i have a problem on usb internet key..i did not run automatically, on the device manager show a question mark on dvd/cd rom, but when i update the driver it keep say is up to date,,,
Jan 27, 2011 | Acer Ferrari 3200 Notebook
What are the upgrade possibilities for my 80GB ATA100 HD on my ferrari 3200 Acer laptop?
For reference only see here (any of them)
http://www.scan.co.uk/Shop/Computer-Hardware/All/Hard-Drives-Int/IDE-%28PATA%29-40GB-200GB/IDE-%28PATA%29-250GBplus
Aug 11, 2010 | Computers & Internet
(ACER ferrari 3200)earphone and disc drive
The headphone jack is soldered directly to the motherboard. finding a new one and getting it soldered on is the only option. As to the dvd I would remove it (one screw holds it in either on the bottom or under the keyboard) finding the model number and ordering a new one on ebay
Jul 15, 2009 | Acer Ferrari 3200 Notebook
Acer ferrari 3500 problem
Your video card in the laptop is failing. If you remove it, reapply new thermal paste and clean it all out while you are in there it may be fine.
Heat will cause all of your stated issues, as well as doing damage to the video card.
Laptops have a habit of building up dust and hair on the fins of the heatsinks causing them to bocome blocked and should be cleaned every 6 months at least.
Oct 11, 2008 | Acer Ferrari 3200 Notebook
Acer ferrari display problem
If you mean like squares of pixels then it will be the video memory on your video card failing or over heating.
Check the video card and make sure it's not clogged with hair and dust etc and reseat it. Also use good thermal paste when you put it back together between the heat sink and the GPU.
If that fails to improve things then a new video card will sort it right out.
You could always send it to me.. I have a thing for Ferrari's ;)
May 23, 2008 | Acer Ferrari 3200 Notebook
Hard drive
To change a drive is not hard at all,ones u can identify it then un screw the ferrari 3200 and replace the drive.Note:while replacing u must take note of how u un screw it and where u un screw it and make sure u dont lost any screw or misplace the connector when u are screwling the drive back.and before u replace any drive at all make sure the system is off and make sure to romove the battery b4 removing any drive to avoid burning of the motherboard.
May 14, 2008 | Acer Ferrari 3200 Notebook
Acer ferrari 3200 pc notebook problem
Hello. Vista needs a repair. You will want to start by putting in your own vista disc or borrowing one from someone. If your laptop isn't booting from the disc, then enter the bios (by hitting f2 or f12 usually) at bootup and select the DVD/CD rom drive to boot first. When the vista disc loads you will want to select recovery tools. Then select "startup repair". That should fix your problem.
Apr 12, 2008 | Acer Ferrari 3200 Notebook
Acer 3200 Ferrari !! Urgent
 First I would try a system restore to before the point when you first started getting the blue screen,it could possibly be a driver update conflict.
Mar 25, 2008 | Acer Ferrari 3200 Notebook
Acer Ferrari 3200 Notebook Logo
147 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
