Question about Vector Manufacturing Simple Start Battery Booster Car Starter
Need plug for model vec019 pro charge portable power station to recharge it.
Which batteries to use for hand set.rechargeble or otherwise
use the same type of rechargeable batteries it came with. not all rechargeable batteries need the same type of charger. make sure the charging station is plugged in, and see if the charge light is on on the phone. phone light should lite up should when placed in the charger. if not... see if the plug in transformer is putting out the needed voltage, center of plug is "+" if dc voltage. also make sure that plug in into the bottom of charging station tightly. also make sure the batteries if separate cells are in the phone correctly. springs go to the smooth bottom end which gets inserted first.
Feb 27, 2015 | Lands Phones
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
How to charge
• IMPORTANT: This unit is delivered partially charged.
Plug into an extension cord FOR 40
hours before using.
You cannot overcharge the unit using the AC charging method.
• To recharge this unit, use only the supplied AC charging adapter.
• All ON/OFF switches should be in the OFF position when the unit is charging or not in use. Make sure all switches are in the OFF position before charging. Here is the instruction book:
http://ecx.images-amazon.com/images/I/81US%2Bom6xKS.pdf
here is the booklet.
Jul 21, 2014 | Stanley Tools 500W Portable Power Station"
Philips pocket memo LFH 9730
Hello I don't recognize that model may be you try to say Philips Digital Pocket Memo LFH9370.
Your unit charges two ways via power supply direct on the portable or via docking station, make sure you have the proper rechargeable batteries you must have the LFH9154 if you don't have this batteries you can buy them on the next link http://www.tvps.com/Products/Philips-LFH9154-AAA-NiMH-Rechargeable-Batteries---New-9154__PH-LFH9154.aspx
May 06, 2014 | Philips Audio Players & Recorders
Power recharging station
This depends on the make & model of your item ? that means whatever item you are asking about !!! you gave no info as to what you are trying to charge.
Jan 22, 2013 | Cameras
Need replacement battery for I-pod docking station Model#5084
I have a battery from my if-2 by Sonic Impact. My ipod connectionwent bad. Battery and charger available.
Jul 23, 2010 | Sonic Impact Technologies IF22 Docking...
How long will the battery last? Can it be recharged in my car? How long does it take to recharge?
Haier HLT71 portable TV battery is good for about 2 hours.
You can recharge it from your car cigarette lighter jack.
Or from your household 120 VAC wall plug.
It comes with both adaptors you need.
It takes about 8 hours for a full charge.
You can charge the TV while watching it, or you can power it off.
Not sure if it charges faster or the same if you are watching.
If the battery does not give you 2 hours after the first charge, try charging and using it a few more times to bring the battery up to full capacity.
Replacement batteries are available on eBay. Good to have for backup in case of a storm.
Jun 21, 2010 | Haier HLT71 7 in. Portable TV
Gps does not power up at all
do u mean that if the gps is not chargng (taking power) it won't turn on
if yes thats because of the model tomtom
many gps have the same system
Apr 10, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Vector Manufacturing Simple Start Battery Booster Car Starter Logo
61 people viewed this question
Top Vector Electronics - Others Experts
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
