Question about Frigidaire FullFGX831C Size Stack Gas Laundry Center
With the washer, the wash cycle ony comes on if the lid is opend/up, while the spin scycle only works with the lid down/closed. This happens with all three cycles, White/Color/delicate. is it the lid switch or the timing control unit?
  • beerhunter2 Nov 08, 2010
    Ok. why does it only happen at the wash cycle while acting normal with the spin? I just thought if it is a bad switch it be either always on or always \off (contact /no contact).
  • beerhunter2 Nov 11, 2010
    Thanks I will but the part and replace it
  • 4,323 Answers
Hi
The spin operation is performed while the lid is closed, its a normal process. If the timer was bad then the cycle would not get completed. However, in wash cycle the lid switch is getting activated which should not be the case. You'll need to clean the contacts for the lid switch, the switch is getting shorted and is also working in wash cycle. In case the cleaning doesn't help then you'll need to replace the lid switch. Lid switch doesn't come separate, it comes as Lid Lock assembly. Please check part#50 in the below diagram---
You can buy it from this link---
Lid Lock Assembly for FGX831C
Hope this helps... Please post back if you need further assistance.
Daniel
Posted on Nov 09, 2010
  • 2,382 Answers
Hi, the problem with the lid switch which you need to replace to restore it back to the proper way......
Posted on Nov 08, 2010
  • Tunde Autos
    Tunde Autos Nov 09, 2010
    It seems the lid switch is having a partial contact problem which make is malfunction....
  • Tunde Autos
I have an older maytag commercial washer . The motor hums when it is ready to spin after the rince cycle. If I lift the lid immediatly and wait about 2 minutes, then close the lid the machine starts and...
The lid activates a micro switch. If it is not pushed down properly it waont spin. This switch is meant to inhibit the spinning process for safety reasons.
Jan 03, 2018 | Washing Machines
MY MOFFAT WASHER SPIN SCYCLE WILL NOT WORK THE WASHER WIL NOT SPIN TO REMOVE THE WATER
moffat washing machine does not remove water after spin cycle
May 29, 2010 | Washing Machines
Trying to locate the belt on a Whirlpool washer
Hi:
Your washer does not have a belt. It has a transmission, and they seem not to fail very often. Usually, the problem lies with the timer or some other switch. What exactly happens when your spin cycle comes around? Normally, after the wash cycle, the machine stops, then the spin cycle starts in the opposite rotation. The first thing that happens is the water is pumped out, then as the speed increases, the spinning throws the rest of the water out of your clothes. If your machine does pump down the water, but doesn't spin fast, then you might have a transmission problem, but if it also fails to pump out the water, you could have a timer or switch problem, as some machines won't spin with the lid open, and if the switch is broken, the machine thinks the lid is open.
Feb 15, 2010 | Whirlpool Washing Machines
Machine not spinning
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Washing Machines
Stops at spin cycle
Open the lid to the washer and let it down gently. You should hear a click when the lid closes. If you don't hear it, the lid switch might be faulty and this will prevent the washer from going into spin. Not an expensive repair.
http://tclaundryrepair.com/
Feb 20, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Kenmore 44152 3.5 high capicity washer will not spin
Open the lid of the washer and let it down gently to see if you hear a click when it closes. There is a lid switch that sometimes fails and prevents the washer from going into a spin cycle. If you don't hear the click when the lid closes, then you may need to have the lid switch replaced.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Washing Machines
Washer Doesn't move from cycle to cycle
this washer has a problem with the lid hinge screws coming loose. check the left hand hinge and you will find the screws loose.
this cause the lid switch to not engage and then nothing will happen until it thinks the lid is closed.
try to tighten the screws and listen to see if the switch "clicks" when you open and close the lid.
that should fix it until the screws come loose again.
Jan 30, 2009 | Whirlpool LSR6334LQ Top Load Washer
Washer will not start
It sounds like the lid switch may be bad or have come loose. Open the lid and there should be a thing on the underside that pokes into the washer when you close it. At the place where it pokes into the washer you should see the top of the lid switch and it should be flush with the washer body. Stick a screwdriver into that hole to push down the switch and it should click. Pull the screwdriver out and it should click again. If it does click then close the lid slowly and listen closely near the switch to see if you still hear the clicking.
If you don't hear the clicking, then you will have to change the lid switch (usually costs about 30-50 dollars) or just bypass it. If you do bypass it, be careful. It will still spin even with the lid open and can be dangerous.
Dec 05, 2007 | Roper RAX4232KQ Top Load Washer
Washer won't complete spin cycle
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
Jan 06, 2018 | Maytag Neptune MAH6700A Front Load Washer
Washing machine trouble
it sounds as if your lid switch is out of position. in the past depending on the model i have taped a penny or two to the top of the switch so the plunger makes contact
Jul 21, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire FullFGX831C Size Stack Gas Laundry Center Logo
79 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
