Question about HP OfficeJet 7310 All-In-One InkJet Printer
I am not able to scan, the printer is displaying that there are no scan options
  • HP Master
  • 7,733 Answers
How can I install "scan" option in display of Canon irc3170 printer?
http://www.usa.canon.com/cpr/pdf/Brochures/copier_c3170_spec_sheet_rev.pdf
Canon Contact Us
According to the Cannon web site, the 3170 series printers do have the scan feature. I suggest you contact Cannon directly for information about the scan feature.
May 01, 2014 | Canon imageRUNNER C3170U Color Copier
HP Officejet 5610 all in one When i try to scan
If you have windows vista and it comes up with the "no scan options" don't press the button on the printer, go to "start" then "accessories" then "paint". This will open up the windows paint program. Go to "File" then click on "From scanner or printer". It will then scan the document, no more problems
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 14, 2011 | HP Office Equipment & Supplies
How to scan more than 1 page at a time
ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. Open HP Solution Center with one of the following methods:
  1. Click Start , click All Programs , click the HP folder, and then click HP Solution Center
  • Double-click the HP Solution Center icon on your desktop. A "Scanning from..." screen displays to prompt for scan settings. If this settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. Click Scan Settings , and then click the appropriate option from the popup menu: Scan Picture Settings or Scan Document Settings .
    3. Select the check box, Prompt for settings at the time of scan , and then click OK .
    4. Click Home , and then start the scan again.On the "Scanning from..." screen, click the appropriate option under "Scan Shortcuts" on the left. Each shortcut has a default group of settings that display when you click it.
  • Click Change Settings , and then read through the drop-down menu choices for all of the settings for the shortcut, adjusting any settings as necessary. Also click the Advanced Picture Settings button and the Save to file Save Options button to view your choices and make any changes. Important : HP Solution Center versions and options vary, depending on your printer. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  • Click Scan . The preview screen might display, if you selected the option to show a preview. Use the options on the preview screen to make any desired adjustments before you finish the scan.
  • After the scan completes, it goes to the destination that you specified in the settings.
  • Scan Button: HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want. NOTE: The steps to set up the scan button on your printer can vary depending on your printer model, and the version of software that is installed. For specific instructions, click the Help button on the home screen or settings screens in HP Solution Center.
    Dec 04, 2010 | HP Officejet 6310 All-In-One InkJet...
    When trying to scan a photo from the c7280 to the computer the printer displays the following error message No Scan Options : refer to documentation and troubleshoot. This is not covered in my printer...
    That's because it's not a printer problem. The scan options are in your computer in the scanning software for your machine. Before you can scan you need to be connected to your computer with scan software running to tell it how to scan, what you're scanning, and where to send and save the image you scan.
    Apr 20, 2010 | HP Photosmart C7280 Laser Printer
    Printer works, cannot scan (same issue as gemrise)
    Yes, just like it says, you need a scanning software running on your computer, there are no options until you have the scanning software running and it knows where to send the image and how to save it.
    Nov 20, 2009 | HP PSC 2410 All-In-One InkJet Printer
    When i am going for scan my machine display this massge this function requires optional equipment
    Image Runner 3300 or (iR3300) copiers do not come with print/scan OPTIONS installed. These functions must be enabled by installing the correct 'kit'....same with fax option...again, these were 'options' when this machine was introduced, no print, scan, fax,...unless options were added to it. Yes, the buttons are there, however.....
    Nov 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
    Problems Scanning
    I would delete the twain scanning driver and reinstall, but first disconnect the usb cable from the pc and reconnect after you install the scanning software.
    Aug 09, 2009 | HP Officejet 5610 All-In-One InkJet...
    Printer pixma 780
    Press MENU SCAN COPY than SCAN
    Cycle throught options until #7 PRINTER
    Pres OK
    Cycle throught options untill #5 INK ABS CAP
    Press OK
    Display SUCTION
    Enter 0
    Press OK
    Turn Printer off
    Pause
    Turn Printer back on
    Feb 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    HP OfficeJet 7310 All-In-One InkJet Printer Logo
    46 people viewed this question
    Seeker5211
    Seeker5211
