Question about Epic View 550 Treadmill
Hello, My EPIC is less than a year old. The problem is when we are walking it varies in speed several times during my work out. Very annoying.
  • 3 Answers
Check that the wire harness in the right hand side upright is really snapped correctly
Posted on Jan 10, 2011
Millermatic 135 doesn't have any wire speed adjustment, the wire speed will vary according to voltage setting but isn't adjustable on the speed control dial?
I bet it runs too fast. Bad board. Buy a new one, or have that one repaired. If it is less than three years old, then it is warranty.
Jan 29, 2015 | Welding Tools
Speed sensor
Could also be a belt and deck issue. Have you lubed under the walking belt? Lube you must get direct from them. Loose drive belt could also cause the belt to feel like it is slipping.
Apr 06, 2014 | Landice Exercise & Fitness
8 year old jade dishwasher has suddenly become very noisy
Eight years is a lot of dishwashing. There are hoses, belts and gears- all of them wear- and the noise is part of the result. Especially when it works hardest.
I doubt it can be repaired for less than its is worth
Time to visit Amazon
Mar 08, 2014 | Jade Dishwashers
It shut offs
Questions for analysis:
How old is this machine?
What is the condition of the walking belt and deck?
(most problems with treadmills cutting off during use stem from worn walking belts and decks - replacement is always recommended unless unit is less than 1 year old)
If you are able to walk on the edges of the walking belt (away from the center of the deck), run a test to determine if unit is still shutting off. If not this may be another indication of excess friction in the center (walking) area of the walking belt/deck. The only way to be accurate about this test would be to perform an amperage test, testing the machine unloaded, with load at 3mph, and with load walking on the edges of the walking belt
Nov 25, 2013 | Life Fitness T5-0 Treadmill
When i start the car and begin to drive, the steering wheel vibrates, as i pick up speed it stops, i've had the tires rotated and balanced several times, it's fine for a while than it starts again???
These may not be your problems since it is occurring even at low speed but you might have the car just free of the ground and rotate each wheel and watch the clearance while you do it for changing clearance. This will reveal 'out-of-round' tires; it happens. Second; but less likely, I had this annoying problem of two speed ranges, around the 30 MPH and 70 MPH points causing wheel shake and it only stopped after I tossed the original brake rotors and replaced them with Brembos.
In 50+ years of driving, poor tires have happened several times and brake rotors twice. There was a feature of a now-defunct chain called 4-Day Tires that kept me going back called 'tire matching.' All replaced tires were checked and then shaved slightly to correct for roundness. With this done, I never had any loss of balance during the life of the tires. Haven't found this offered anywhere else since then; too bad.
Jan 26, 2011 | Kia Spectra Cars & Trucks
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
F1 code when start Whirlpool Cabrio Washer and sometimes during cycle - my machine is about a year old. Should I call a repairman or live with it?
control problem probably main control module..if in warranty (less than 1 year)CALL REPAIR NOW!!!!!!!!!!!!!! if not as long as it doesn't get too annoying or quits completely use it..control 200-275
Sep 06, 2008 | Whirlpool Washing Machines
F 70 code on the Kenmore elete smartheat HE4
hello Whgispers42,
Huuum At your service!
You said,
We frequently have to start the dryer several times during one load. The dryer will run fine for a while then all the sudden give 3 beeps and then the F 70 code. Sometimes when you go to start the dryer you can press power and the panel will light up for about 3 - 5 seconds and then shut off again, this will happen several times in a row. We have been unable to solve this issue ourselves and are becoming very frustrated since this washer/dryer set are less than a year old. Any help you could offer would be greatly appreciated. (If we are unable to fix this problem soon, it is likely that the dryer will make a sudden leap from the second floor window to the backyard)
Try this first!!
This is an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not help, you said the machine is not one year old.
All appliances have a 1 -year warranty and the service and parts are free for that first year!
I hope you succeed with my recommendations.
Please contact me with your progress1
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Jul 27, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Epic Washer high spin shaking, AND high-pitched sound coming out of washer
When someone reports severe vibration during spin on a brand new washer, the first question always has to be whether the transit brackets have been left in.
Washers are designed so that the drum and motor float on a collection of springs and shock absorbers. To prevent damage to these during shipping, a set of brackets is used to bolt the floating assembly to the case. If these aren't removed before first use (the manual will say how to do it) havoc ensues.
The irritating whine is a new one on me.
A.
Jul 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Epic View 550 Treadmill Logo
114 people viewed this question
Top Epic Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
