I have reconnected the printer to my computer and when I turn it on the ink cartridges slide from side to side really quickly and loudly and I cann't get it to do anything but that
    Sniper:
  • 86 Answers
There is a thin plastick strip inside the printer.When you open the top cover you can see it.The printer knows where are the printer heads trough this strip.If the strip is broken the the ink cartridges will move from side to side with loud noise when they hit the left or right end of the printer.To repair it you are going to need a New strip and prof, service help.Please vote if that was helpfull!!!!
Posted on Nov 08, 2010
Epson C60When I press the ink replacement button, the print head doesn't move to the center. Previously, I had purchased a ink cartridge that turned out to be too large, so I took the ink cartridge...
Unplug the printer from computer, then Unplug the printer from wall when the carriage is all the way to the left, then manually slide it to the area where you can open the ink cartridges, pull all ink cartridges out, close cover and turn printer on. Printer should now be acting as it should.
May 17, 2017 | Epson Stylus C60 InkJet Printer
Hi, when I power up my MP630, there is a loud clacking sound and then I get an error code of 5100 of 5C20. There is no paper jamed - can you help?
Error Code 5100
It can have a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. The purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on)
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can't remember exactly what it said but it was something like that).
8. Open printer, lift the gray arm that surrounds the ink cartridge area and reinsert the ink cartridge holder (with the ink cartridges in it). Lower the gray arm.
9. Close printer cover.
10. The display should appear normal now, and you should be able to print again.
Jul 09, 2011 | Office Equipment & Supplies
How do I change the ink waste absorber on a canon i9900
Turn the printer off.
Disconnect the AC power cord.
Lift the lid to expose the print-head mechanism.
Look where the ink-cartridges are "parked".
The ink-absorber is below those ink-cartridges.
Close the lid.
Reconnect the AC power cord.
Turn the printer on.
Lift the lid, and wait until the print-head slides away from that "park" position.
Without turning the printer off, disconnect the AC power-cord.
Now, you have access to the absorber.
Change the absorber.
Oct 21, 2010 | Office Equipment & Supplies
Ink cartridge slams from side to side and lights
Epsons often experience this odd problem. This is a sort of tempory fix.
turn printer on allow carriage to leave its base and disconnect the power cord.
Clean the rails the cartridges run on. You should notice the cloth comes away with black stuff.
Use a small amount of sewing machine oil on a cloth and wipe the rails again ( or small amount of wd40 on a cloth.
Slide the carriage along and back a few times. then return it to home and reconnect power cord and turn on. That should get it to behave for a few more weeks/months. If it continues, then the head is damaged and will have to be renewed or buy a new Canon Printer. ( NOT EPSON)
Please rate my help++++Thanks for using FIXYA
Jul 01, 2010 | Epson Stylus C88 InkJet Photo Printer
Ink cartirdge cannot be recognized even though correct cartidge was installed
Hi there
You can try this but it lots to do but may help
This message may be resolved by resetting the unit. Please follow these
steps:
1. With the printer powered on, open the cover. The ink will move to
the left hand side.
2. Push down on the end of the black cartridge. A clicking noise will
be heard.
3. Slide the cartridge out of the holder towards you.
4. Push down on the end of the colour cartridge. A clicking noise will
be heard.
5. Slide the cartridge out of the holder towards you.
6. Once both cartridges are removed, unplug the power to the printer
(without turning it off).
7. Reconnect the power cord.
8. Turn on the printer.
9. Open the cover. The carriage that holds the ink will move to the
left hand side.
10. Make sure the orange cap is off of the bottom of the black
cartridge.
11. Place the black cartridge in the bottom of the printer.
12. Slide the black cartridge back until is cannot go back any further.
13. Push up on the end of the black cartridge, a clicking noise should
be heard.
14. Make sure the orange cap is off of the bottom of the colour
cartridge.
15. Place the colour cartridge in the bottom of the printer.
16 Slide the colour cartridge back until is cannot go back any further.
17. Push up on the end of the colour cartridge, a clicking noise should
be heard.
Please note that the colour cartridge will stick out further than the
black cartridge.
Close the cover. The printer should make some noise for a few moments,
and then return to standby.
If the message persists, to clear the low ink-warning message, press and
hold down the button for at five seconds, and then release
it. This will disable the ink detection until that cartridge has been
replaced.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon PIXMA MP470 All-in-One Printer
Error - says can't recognize an ink cartridge
Hi there
steps:
the left hand side.
be heard.
be heard.
left hand side.
cartridge.
be heard.
cartridge.
be heard.
black cartridge.
replaced.
Feb 09, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Where do you insert the ink cartridges on lexmark x4650
These are the instructions for X2500 Printer
1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
2.Open the top portion of the printer to reveal the ink cartridges.
3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Oct 25, 2009 | Lexmark X2500 All-In-One Printer
Printer says, "Ink scrubber" is full and it will no longer print
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-6
Aug 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer says low level color ink fitted new ink printed ok at first but still said low ink order now and will not let me print or scan
Dear customer,
The most common solution is to follow the steps as follows
1. unplug the power cord
2. press and hold down the <ON/OFF> button and reconnect the power cord
3. press the <STOP/RESET> button 2 times and then release the <ON/OFF> button
4. Display LED show "0" press the <+> button 1 time Display LED show "1"
5. press the <Start Color > button 2 times and then press the <ON/OFF> button waitng for testing out 2 pages
6. Open the cover. The carriage that holds the ink will move to the left hand side. and then unplug the power to the printer
7. Push down on the end of the black cartridge. A clicking noise will be heard.
8. Slide the cartridge out of the holder towards you.
9. Push down on the end of the color cartridge. A clicking noise will be heard.
10. Slide the cartridge out of the holder towards you.
11. Once both cartridges are removed, unplug the power to the printer (without turning it off).
12. Reconnect the power cord.
13. Turn on the printer.
14. Open the cover. The carriage that holds the ink will move to the left hand side.
15. Place the black cartridge in the bottom of the printer.
16. Slide the black cartridge back until is cannot go back any further.
17. Push up on the end of the black cartridge, a clicking noise should
be heard.
18. Place the color cartridge in the bottom of the printer.
19 Slide the color cartridge back until is cannot go back any further.
20. Push up on the end of the color cartridge, a clicking noise should
be heard.
hope its udeful. thank you.
Jul 09, 2008 | Office Equipment & Supplies
Ink level counter disabled, not recognizing new (refilled) cartridge.
hi,
prito-i-24
Jan 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
jasbo
jasbo
