Question about Toyota Sewing Machines
Toyota Mini, Model 6004. I have the bobbin threaded, but don't know how to start the engine so it will fill the bobbin.
  • 323 Answers
SOURCE: Threading & bobbin won't pick up
Make sure the needle is inserted all the way in with the long groove to the left.
Threading is through 1)the thread guide 2)The tension 3)The take up lever 4) The needle eye (left to right).
Remove the needle plate, thread the machine. Turn the hand wheel and watch the thread in the needle to see if it is above the eye of the needle. If it is, the machine needs to be retimed.
Sewman7
Posted on May 14, 2008
bargainbox
  • 1388 Answers
SOURCE: bobbin filling
The handwheel may have a pull out/push in action to disengage/engage the clutch, or it may automatically disengage when the bobbin winder is moved to the right for winding........hold a short tail of thread to get it started and you should be away.
Move the winder to the left for sewing, or push handwheel in, according to the mechanism.
Posted on Jun 01, 2008
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
Mongo32
  • 111 Answers
SOURCE: janome mini not picking up the bobbin thread!
needle in backwards?
Posted on Aug 23, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
Not catching to wind the bobbin
you have to hold the loose end for a few seconds .
Mar 20, 2016 | Sewing Machines
Janome sew mini will not fill the bobbin
a part of the bobbin winder is not working and should be checked
Mar 25, 2014 | Janome SEW MINI Mechanical Sewing Machine
When i start sewing the thread tangles and seizes up within 3-4 stitches. I've removed and cleaned the bobbin case a few times.
change the needle
make sure the thread has not come off of the thread take up lever
rethread the machine top & bobbin,, make sure to use every
thread guide
make sure to not over fill the bobbin,, make sure the bobbin is not
warped or damaged
Aug 31, 2012 | Janome DC3050 Computerized Sewing Machine
Bobbin winder stop before befor fully wound
Is the bobbin close to full in the middle but not that full above and below? You may need to watch the bobbin wind and give the thread a nudge so that it fills right across the bobbin core to avoid this happening. Most bobbin winders will click off before the bobbin is completely full as you don't want any thread actually touching the bobbin case when it is in position, just fill to about 80% for good tension and stitching.
Oct 10, 2011 | Brother CS-8060 Computerized Sewing...
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Bobbin tension problem with kenmore model 385.16231300
If You have a drop in bobbin you will have to remove the hook and adjust the tension, however try adjusting the top tension before you remove the hook.
Jul 17, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
246 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
