Question about Whirlpool GBS277PD Electric Single Oven
Whirlpool gold super capacity oen
F5 message appears when trying to use oven. Worked fine yesterday!
  • 525 Answers
F5 is a common door latch failure or adjustment code. You may have simply bumped or repositioned something concerning the door latch assy. maybe during a routine wipedown? You can investigate this via your instruction manual.
Post me back if I may be of further assistance.
Thank you,
Dave E. (Illeagle)
Posted on Jun 16, 2008
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
Whirlpool Gold Self-Cleaning Oven Error Message: E1 F5. What does it mean and can I fix it?
E1-F5 means the self clean latch will not lock.
Try pressing down any key and hold for 1 minute, see if this clears it. If not you will most likely need the latch switch replacing.
Dec 20, 2010 | Ovens
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
Whirpool Super Capacity 465 Self-Cleaning Gas Range error code F5
facing the front of the oven (while off) put your hand along the back of the oven toward the top left side. there should be a techinical spec sheet with a list of what the codes mean and possable solutions.
Mar 08, 2008 | Whirlpool SB160PEE Gas Single Oven
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
Jun 19, 2007 | Whirlpool GBS307PR Electric Single Oven
Whirlpool GBS277PD Electric Single Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
