Question about Kenmore 44102 Front Load Washer
Kenmore Washer 4410 won't spin
I removed the bottom front panel and the first thing I see is that it appears the two shocks have broken away from the bottom mounts. Would this cause the washer to not spin?
  • 1,294 Answers
Some wires may have come loose. Maybe your belt could have come off. First replace the two shocks carefully seeing how they were fitted in.
Try these sites (which is good)
Posted on Jun 16, 2008
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
My kenmore elite washer has a very loud banging noise when it spins
U will need to remove the washer drum and check the washer drum stablizers and the washer drum bearing, do this to see what is wrong and how far u need to go in this repair.First open the door and spin the inner tub to make sure the tub spins freely, if not you have big problems.
If it does then remove the lower front panel. There are 3 screws along the very bottom of this panel that you can remove and then the panel will come off. Check to make sure the shocks are not cracked or broken under the tub. If not and the unit just recently started shaking a lot, then replace the shocks as they are probably worn out. If it's been shaking since the day you've gotten it and it just seems to have gotten a little worse, then purchase Shake Away pads which are specifically designed for front load washers to sit under the feet of the washer and reduce vibration dramatically.
May 07, 2010 | Washing Machines
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
My Kenmore front load washer just bgan to goes out of balance
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 08, 2009 | Kenmore 43142 Front Load Washer
Broken shock absorbers on front loading Kenmore
Hi, first things first. Your model and serial numbers should be on a sticker somewhere around the door opening. Next check the tub. With your finger,push up on the rim of the tub then rotate the tub a few inches and push up again. Continue through a whole rotation. If the tub moves and make a clicking noise you have a bad drum bearing and the cost to repair is more than the unit is worth. If that's not an issue,then it's probably just the shocks,replacing them should solve the problem. Hope that helps.
Mar 21, 2017 | Kenmore Elite 45986 Front Load Washer
My kenmore 417.42042100 model front loading washer is making a loud banging noise during the spin cycle.
Here's what the problem is.
It's been designed to fail so that you buy an expensive part.
Nov 26, 2008 | Kenmore 46462 Front Load Washer
Washer doesn't drain or spin
remove bottom panel dip as much water as possible out if possible lean washer backward to keep as much as possible away from pump inlet remove clean out port plug by turning counterclockwise clean debris from pump impeller
Jun 05, 2008 | Kenmore Elite 45986 Front Load Washer
Replace shock
no special tools are required. also remove the top of washer and check the 2 springs that are holding from above,as faar as acessing the should have a removable back panel, sometimes an opening on bottom of machine
Mar 14, 2008 | Kenmore 46462 Front Load Washer
Kenmore 416.82042042
Remove the botton front panel and look at both sides towards the bottom. There are mini shock absorbers. Most likely, one is broken. They are only $16.99 each at (part # 131268200). There is also a counterweight on the left side that may be invlolved. I just opened my washer and saw the counter weight laying loose on the floor. Not sure if DIYJim can tackle this job or not............
Dec 06, 2007 | Kenmore 43142 Front Load Washer
Whirlpool Duet Washer
dc, drop the front bottom panel and make sure the 4 shocks are connected to the tub and bottom panel, then check the front and rear counterweights. They may have loosened up. Remove back panel or top to check the rear counterweight. The top removes by removing the 3 screws in back and it slides off. If all this checks ok then I would suspect the rear bearing wollowing out. back.
Apr 01, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 44102 Front Load Washer Logo
50 people viewed this question
Sal De
 Brian Main
Brian Main
