Question about Campbell Hausfeld 26 - Gallon Air Compressor
The Campbell hausfeld Air Compressor Model #wl660001aj 5 hp 22 gal 120 v will not shut off. What could be the problem.
3 Suggested Answers
SOURCE: Need new pressure regulator for Campbell Hausfeld
Friend had some pressure regulators and one of them fit. It is also a step up from a direct replacement OEM part. Thank you for your responce to my question.
Posted on Feb 01, 2010
  • 1274 Answers
SOURCE: I need to replace the
Hi, my name is John. Welcome to FixYa. Take the belt with you to most any auto parts store and they will match one up for you. Thanks for choosing FixYa...John
Posted on Nov 23, 2010
Campbell Hausfeld Air Compressor 1.8hp 135 max psi 20 gal wl611800aj the prob is there is a fluild leaking from the motor
You compressor is listed as being oil free. The only liquids that could possibly leak out of the motor (if still from factory condition) is black substance from overheated capacitor/s or grease from a failing bearing. Remove capacitor covers and check for failed cap. Motor bearings will become noisy before failure. Capacitors are available from motor repair shops and many times on ebay. Replace with same uf rating and same or higher voltage. Some caps are larger /smaller with same reading (notice size so cap cover will fit). Good luck
Jul 11, 2011 | Campbell Hausfeld 1NNF5 Air Compressor,...
Where the oil goes on model wl660001aj aircompressor
I don't find your model ... based on the picture you posted, I would say it is a oil-less compressor. Typically, the oil would be filled through a plug not unlike the one you would find on your lawn mower. Did you not receive a owners manual with this compressor when you purchased it? Have you inquired at either of the Campbell or Husky web sites?
http://huskyaircompressor.us/
http://www.cpocampbellhausfeld.com/
http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?langId=-1&storeId=10051&catalogId=10001
Thanks for for your question @ FixYa.com
Apr 01, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My Campbell Hausfeld compressor model WL650101AJ will only pump to 80psi and will not shut off.
TAKE THE COVER OF THE TOP HAS 2 PHILLIPS SCREWS AND SNAPS OFF. THERE IS A COPPER TUBE THAT GOES BETWEEN THE COMPRESSOR HEAD AND THE CHECK VALVE TAKE THE TUBE COMPRESSION NUTS LOOSE AND REMOVE THE TUBE. CHECK THE RUBBER SEALS IF THEY ARE MISSING OR TORN YOUR COMPRESSOR LEAKS WHEN IT IS RUNNING BUT IF YOU SHUT IT OF THERE IS NO AIR IN THE PIPE SO CHECKING IT WITH IT OF WONT DETECT THE LEAK. MY COMPRESSOR WAS DOING THE SAME THING AN THIS FIXED IT.
Jan 26, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I need to replace the belt on my 5 HP 120 volt 27 gal tank Model WL660001AJ Air compressor. I don't know the part number on the belt, or where to purchase. Can you help?
Nov 19, 2010 | Campbell Hausfeld 26 - Gallon Air...
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Feb 01, 2010 | Campbell Hausfeld Air Tools & Compressors
Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Mar 15, 2009 | Air Tools & Compressors
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
651 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
john h
elunsford
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
