Question about Dishwashers
It does not matter what setting I choose the program reverts back to the "fast" cycle and stops
  • 4,323 Answers
Hi
The issue can be with the Timer going bad and needs replacement. When the cycle wont complete or as in your case reverts back to the fast cycle then it is the timer that is bad and needs replacement. Hope this helps...for any further help you can post back with the make and model# of your Dishwasher.
Daniel
Posted on Nov 08, 2010
Pr5 message is displayed
the electronic program is corrupt. just use an alternative setting.
Mar 10, 2014 | IFB Washing Machines
Extra Rinse switch "OFF" does not work
Possible fault with the timer or switch , reset the program to another mode and check if the program resets.
Jan 22, 2013 | Maytag Centennial 3.2 cu. ft. SuperSize...
My commercial cool air conditioner goes off after 5 min. The stop light is flashing? I can't get it to go on?
It's going thru the defrost cycle. Once that ends, the unit should restart. If it doesn't wait until 3 minutes have elapsed, after the stop light goes out and restart the unit. If that fails, turn the Master ON/OFF Switch to OFF & unplug the unit. Wait 15 minutes, plug the unit back in and turn the Master ON/OFF Switch to ON. The unit should have reverted back to the original factory settings. If so, reset the controls as you like.
I hope this helped you and thanks for choosing FixYa.
Jul 24, 2011 | Haier CPN14XC9 Air Conditioner
Hi FixYa, Selection of any drying program - after hitting the start button - will revert to the "Damp for machine ironing" position. It doesn't matter whether the control light indicates...
I am assuming that it is a sensor underneath the lint screen needs to be cleaned, if not then it maybe the control board but here is a manual and it has a service number, Good Luck Tim:
http://www.hammerwall.com/Download_Manual/18681/
May 23, 2011 | Danby DCD5505W Electric Dryer
Pictures come out very grainy
Most likely, you've set the ISO value higher than necessary for most circumstances. You may have done this deliberately to catch some fast action, or you accidentally hit the ISO button without realizing it. If you reset to lower ISO settings, your graininess problem will probably disappear.
The faster the "film speed", whether you're using real film or a digital camera, the more grainy the pictures will be. ISO is the film speed. The ISO speed is set by pressing the ISO button (just above the "FUNC SET" button); it cycles thru AUTO, HI, 80,100, 200, 400, 800, 1600, then back to AUTO. If you've set the camera to AUTO on the control wheel opn the top of the camera, then you can only select ISO of AUTO or HI (which is slightly faster than AUTO).
The higher ISO settings are useful in low light conditions or to catch fast action, but those higher settings should not be used otherwise because of the increased graininess.
I hope this helps you.
Oct 19, 2008 | Canon PowerShot A540 Digital Camera
Ysstem will not back up, transient error, code 0X800423F3
1) Start the computer and press f8 on boot up and select 'Safe Mode without networking'.
2) In the start menu type 'cmd' (without quotes) and on the top search result right click the program and choose 'run as administrator'
3) Type "net stop winmgmt" without quotes and press enter to make certain the WindowsManagementInstrumentation (WMI) service is not running.
4) In the start menu click 'computer' on the right hand side. Go to the windows\system32\WBEM\ folder and rename the Repository folder to something else like OLDRepository (right click and choose 'Rename Folder'.
5) Reboot and restart as normal.
6) In the start menu type 'cmd' (without quotes) and at the top right click the program and choose 'run as administrator'
7) Type 'net stop winmgmt' (without quotes) and press enter to stop the wmi service.
8) Type 'winmgmt /resetRepository' (without quotes) and restart the system.
Reference: http://www.vistaforums.com/Forum/Topic14017-9-1.aspx
Jul 13, 2008 | Computers & Internet
Dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Feb 27, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
