Question about Gateway 450ROG Notebook
Ram For a Gateway 450Rog
I was wondering what was the mas ram this latop will hold? Thanks
Hi Jeremy: I have the same computer and I've installed 2 ea. P/N SHTYGD1648F124333 1024MB SDRAM PC2700MHz (166MHz) and this thing flies. I've had absolutly no problems since installed on 17 Jan 2008. The chip is manuf. by Samsung
Posted on Dec 30, 2008
  • 385 Answers
The maximum memory size for this laptop is 1 Gig of memory.
You can see for yourself at this link.
It's a pleasure to be of help!
Lolita
Posted on Jun 16, 2008
Freezing and crashing issues
http://support.gateway.com/s/PC/R/GTModels/5648/5648sp3.shtml
PLACE 1 GB RAM IN THE SLOTS.
UNINSTALL PROGRAMS YOU DON'T USE OR NEED.
Dec 28, 2013 | Gateway Computers & Internet
I have the 450rog and it got dropped onto the floor and the screen like died
Diagnose.
Check for loose connections first.
Harddrive, Ram Memory. Make sure they are plugged in tightly.
Make sure the Battery is plugged in tight, (AC adapter { Charger} NOT connected)
If it is the version with dual battery's, make sure you check them both.
Past this point it may be a cracked circuit trace on the motherboard, caused by a broken motherboard.
(Circuit Trace. Also known as Signal Trace.
Think, very flat thin copper wires that go all over the motherboard)
[Laptop turned over, Battery facing AWAY from you;
The Memory Bay Compartment is to the far right/middle.
One Philips head screw to loosen, then the compartment door can be raised up on the screw side, and compartment door lifted out.
Note the small tabs on the compartment door, and opposite of the screw side.
REMEMBER,
Remove the ram memory module { 'Stick' } at a 30 degree angle. When you spread the spring locks on each side, of a ram memory module, and it pops up; THAT is the same angle to remove it.
Bring it straight up when removing, and you will DAMAGE the gold plated contact pins on the bottom of the Ram Memory module, and the contact pins in the bottom of the ram memory slot.
Handle the Ram Memory module by the BODY. The Body is everywhere on the Ram Memory module, except the gold plated contact pins on the bottom.
The Body is coated with a see-through protective plastic.
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Refrain from touching the gold plated contact pins.
You HAVE to remove ALL ram memory modules, and reinstall them. This is the only true method to use, to ensure they are seated tightly, and correctly.
Wireless Module Compartment is to the immediate left of the Memory Bay Compartment. Below it is the Harddrive Bay Compartment.
One Philips head screw is removed, and the Harddrive slides out in it's Harddrive caddy. (Slides out of the side of the laptop)
Do so, then carefully slide it back in. Reinstall the screw.
There are options, and one is a second harddrive. If your model has this option make sure it is plugged in tight also,
http://support.gateway.com/s/Mobile/Gateway/450ROG/3501353sp66.shtml ]
Then,
The external VGA monitor you connected to the laptop;
Laptop OFF, monitor OFF, connect it again.
Hold the Fn key down, and at the same time tap once on the F3 key.
(F3 key is the Display Toggle-Over key)
No display on external VGA monitor? Hold the Fn key down again, and tap once more on the F3 key.
Still bad?
Problem is internal.
Use an ESD wrist strap, and have it's alligator clip attached to a good ground source. (Electro Static Discharge)
One example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
Information,
http://en.wikipedia.org/wiki/ESD_wrist_strap
Make sure the Intel Pentium M processor is seated tightly in it's Socket 479 processor socket,
http://en.wikipedia.org/wiki/Socket_479
Note that the single slot type screw is the locking mechanism.
Turn 180 degrees to unlock, make sure the Processor is seated, then turn the screw back 180 degrees to re-lock the Processor in the processor socket.
Make sure the Thermal Cooling Module is seated tightly afterwards,
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&hash=item27c81332c5&item=170860425925&nma=true&pt=US_CPU_Fans_Heatsinks&rt=nc&si=3aRaG4yZHczJd6Q3wXW2IIvaBys%253D&orig_cvip=true&rt=nc
Since you removed the Thermal Cooling Assembly to see if the Processor was in tightly, the Thermal Paste needs to be replaced.
If a Thermal Pad, peel it off, PROPERLY clean the top of the Processor, and metal plate that sits on it, then Properly apply fresh, new Thermal Paste. Reinstall Thermal Cooling Assembly.
http://www.ebay.com/itm/Gateway-450ROG-INTEL-Motherboard-310A2MB0006-/271036075865?pt=Motherboards&hash=item3f1b024f59
In the link above, and in the large Main view, is shown the Bottom of the motherboard.
(In the two small views shown underneath, the view on the Right is a Top view of the motherboard)
Over to the left/middle you see the black Processor socket.
(Note color does Not matter)
The ATI M7 (Radeon 7500) graphics chipset, is above it,
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Mobility_Radeon_Series
http://www.ebay.com/itm/1X-New-ATI-Mobility-Radeon-7500-216Q7CFBGA13-M7-CSP32-/190413272946
Left side shows the Top view. Right side shows the Bottom view.
Note the Solder Balls.
The ATI graphics chipset (GPU) is soldered directly to the motherboard, with a BGA surface mount.
Ball Grid Array.
View this small video of a BGA Rework Station, and the BGA surface mount technique,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll down, click on the Red -
Take a few minutes to view the IR 650 demo video
IMHO?
If I had possible damage to the motherboard, or thought that the solder joints holding the ATI M7 graphics chipset to the motherboard were cracked, I would buy a replacement motherboard.
I base this on, because I saw motherboards that were stated to be working, and cost was $30 to $40.
Gateway 450 R.O.G. Service Manual download link (Free), to follow in added Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 05, 2012 | Gateway 450ROG Notebook
Hi, I have a 1.5 yr old gateway NV52 laptop that has stayed in sleep mode for two days...I've tried turning it off and cutting back on but it is still in sleep mode...please help
Hi aiomason.
Remove the AC cord and the battery from the notebook. Re-attach battery and AC cord and power up the notebook. This will clear the Ram memory and force the operating system to "Cold Boot", in other words start the operating system loading up from the beginning instead of resuming from Ram the last time it was active. This proceedure should restore your Gateway Notebook to normal operation. Post back your results and good luck.
Jan 24, 2011 | Gateway 450ROG Notebook
When turning on the laptop it beeps3 times and there is no screen
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
hope this helps
Jan 01, 2011 | Gateway 600YGR 600YG2 450ROG COMBO DRIVE...
Laptop beebs
if it starts then beeps then shuts off, turn around your laptop and take off the back plate and see if the fan is loose.
Dec 04, 2009 | Gateway 450ROG Notebook
Memory upgrade not working
It only Accepts two PC–2100 SDRAM memory modules..If both are same then the slot might have some problem...
Jan 29, 2009 | Gateway 450ROG Notebook
Ram upgrade
dear if this is ur latop then suggest u to get it added by a proffesnional as latop need to be opened & then ram to be added..................Sameeraryan
Jan 15, 2009 | Computers & Internet
Wireless lan drivers
Here's a link to Gateway's drivers for your machine. There are several different wireless drivers, you may have to try a few before finding the right one.
http://support.gateway.com/support/drivers/search.asp?param=450rog+drivers&st=kw
Jul 15, 2008 | Gateway 450ROG Notebook
Upgrading
goto the gateway site and check what memory type you need.
If you upgrade to 1064Mb that will increase the performace of your machine
Apr 20, 2008 | Gateway MX3228 Notebook
Upgrade?
Generally you can add more RAM, However, there are too many details that are needed about your system in order determine if an upgrade can be done.
Suggest you call Gateway Support.
Gateway 450ROG Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
