Question about Canon PowerShot SD1100 IS Digital Camera
Lens will not open, turns itself off shortly afterwards
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 30, 2012
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
My camera turns on by itself even with the slide in front in the closed position. The screen then shows the warning that the lens cover is closed. When I open and reclose the lens cover in 10 or so...
Most likely some dirt, dust, or other particle is jamming the lens opening gears. You can try to spray some compressed air into the lens assembly, hopefully dislodging whatever is obstructing the lens cover. If this doesn't work, the camera will have to be serviced, which can be expensive. If the compressed air doesn't work, and you decide to have it fixed, get an estimate first. Often the cost of repair justifies going ahead and purchasing another camera.
Good luck, thanks for using FixYa, and hope this helps!
Aug 05, 2010 | Sony Cyber-shot DSC-T77 Digital Camera
Samsung bl103 will turn on and beep 3 times then pauses and beeps 3 times again and the lens is stuck in the out position
Mine does the same thing. I open the battery door and close it back up. Then I push the power button and the lens will retract. When I turn it on afterwards it works fine. Mine does this quite often.
Jul 22, 2009 | Cameras
Activating camera on sony ericsson C702 makes display go black
Very funny solution, but helpful.
Got the same problem. Display and keyboard lights goes black after lens cover open. I can take pictures and videos.
For a short period of time phone seems to be died after switching camera off. Then lights goes back.
Jul 05, 2009 | Sony Ericsson Cyber-shot C702 Cellular...
Not turning on and has strange smell
Powershot A640 Could Not Be Powered On, Burnt Smell
My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and pushing the on/off button, the on/off indicator blinked once then shut off by itself. After a while, a strange smell came from camera batteries area, and I could feel warm there too. Immediately I took out all the batteries from camera.
When checking the posts here the other day, I tried one solution and got the lens back to close: first took out the memory card from camera, then put the new batteries in; push the on/off button with no memory card. I found the lens retracted a little before camera shut off by itself. I pushed on/off button three times to get the lens fully close. However, the burnt smell came out again. I immediately took out the batteries.
Did I get a short circuit inside? Is there any ways to fix it?
Oct 31, 2008 | Cameras
Lens stuck open after dropping.
Sounds like your lens is out of alignment. Added to that something w/ the screen is affected by the lens. Safest way is to have a technician check it out. A short cut I take is to look at the lens carefully and see if there is something loose or how mis-aligned is the lens. Sometimes a slight nudge will get it working properly. But whether it starts to work or not, the lens is already misaligned and you may still have a problem taking clear pictures. So even with my short cut, I'd still suggest you bring it in for repairs. It's really not a good idea to do short cuts unless you have a budget problem. Take care of your camera and keep the strap around your neck at all times so you don't drop it again.
Jul 16, 2008 | Kodak EasyShare Z1275 Digital Camera
My Onkyo Receiver TX 601 is turning itself off
May not help, but I had the same thing when I turned up the volume.. off it went.. then I found my two surround sound speakers had the wires shorting. Looks like a safety switch if there is a problem. Could check if the wires are crossed, shorted, and/or thick enouch to handle the volume.. test it by just having the stereo speakers enabled. Cheers,
Jan 11, 2008 | Onkyo HTR500 Receiver
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Lens will not open!
This troubleshooting can be due to dirt in the lens cover, needs to be cleaned.
Nov 25, 2006 | Nikon Coolpix 3700 Digital Camera
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Canon PowerShot SD1100 IS Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
