Question about Homelite Mighty Lite Lawn Trimmer
Primer bulb will not take in the fuel in it seems block
    President:
  • Homelite Master
  • 1,545 Answers
A fuel system inspection is needed here. You need to check the intank fuel filter,(make sure its not clogged) the condition of the fuel lines,(soft, not brittle with no tears or cracks) ,the ventin the gas cap,(little rubber tube must allow air in). Foremost, check the condition of the bulb itself:sets in (primer base assembly) that has very small check valves inside it controlling the inflow and outflow of fuel. There cannot be any air leaks as the bulb on the carb and one mounted remotely from the carb depend on a vacuum effect to operate correctly. So some disassembly and acute inspection will be required.
Posted on Nov 08, 2010
When i press the primer bulb in it want pop back out why?
The thing to understand is that this is not a primer, it is a purge and there is a big difference, a primer pushes fuel into the carb, a purge pulls fuel from the carb and dumps back to the tank, so when the bulb is pressed in, fuel in the bulb is pushed back to the tank, when the bulb comes our fuel is sucked from the carb, if the bulb stays in either the filter in the tank is blocked, or the fuel hose is trapped, or the filter in the carb is blocked, or somebody has fitted the pipes on the carb round the wrong way.
May 22, 2018 | Weedeater Garden
Primer bulb not pumping fuel into carb, pull it out, no splits etc. Once I get fuel in it starts and runs fine??
Probably a valve in the priming system is stuck. It allows fuel to flow into the bulb from the tank, the valve should close then and allow the bulb pressure to spray into the carburetor. Could also be the opening into the carburetor from the prime bulb is blocked.
Mar 27, 2015 | Garden
I can't get it to start. Don't think the gas is moving when I pump it to start it. When I push on the bulb, it doesn't appear to pick up fuel.
Is the primer bulb filling with fuel.? If not then you either have a hole in the primer bulb or a hole in the fuel line, you mat also have a blocked primer bulb base.
Aug 03, 2013 | Garden
Primer bulb will not prime
Sounds like it could be a number of faults.
1. Crack in the primer bubble its self, not allowing the creation of pressure or vaccum.
2. The plastic primer base has a valve in it. That could either be blocked or damaged.
3. Blocked up fuel line (not very likely)
4. Hole in the fuel line which is sllowing it to suck air up and not fuel.
I\'d be putting my money on 1 or 2.
Jul 03, 2013 | Husqvarna Garden
My chain saw 14" homelite
primers pull fuel from the carb and dumps it back into the tank, so if the bulb will not prime the chances are the fuel filter in the tank is blocked, pull the fuel hose through the filer hole and replace the filter on the end.
Jan 27, 2011 | Garden
Poulan 2150 gas chain saw. How do I connect new primer bulb to carb and gas tank?
Make sure the tank is filled with fresh fuel mix.Try hooking the line that goes to the tank to one of the two primer ports and operate the bulb. If it does not pull fuel in, reverse the connection to the primer and try the bulb again. Once you get fuel into the bulb, move the tank line to the other port. Install a line from the open port on the primer to the open port on the carburetor. Try the primer bulb again, it should pull new fuel from the carburetor if the two connections at the carburetor have not been reversed. This is a kind of 'hit or miss' business when connecting fuel lines that involve the primer bulb. Nothing seems to be marked on the involved parts. Hope this helps
May 15, 2010 | Garden
Must keep pushing primer bulb to keep mower running, need manual
The main suction jet in your carb. is blocked.Remove the bowl and push a thin needle up the centre jet in the carb and blow the jet out with compressed air. Stephen.
Sep 22, 2009 | Briggs & Stratton Garden
McCulloch Chainsaw carb not getting fuel
This is the same problem I have with a Mac 3200. I have: (1) A line from the primer bulb to the front port on the carburator. (2) line from fuel tank, with attached fuel filter, to the other primer bulb port. (3) Line from port on back of carb. to ????. I thought it must be a pulse line, but not certain, and don't know where to run it to. Please let me know when you find out.
Aug 13, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Homelite Mighty Lite Lawn Trimmer  Logo
170 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
