Canon 4010C When I try to scan multiple papers @ one time my scanner is passing thru 2 or 3 pages @ onetime so not all of my papers are being scanned. We clean the rollers & the glass frequently. Thank you Robin
    Guru:
  • 1,894 Answers
Hmmm i thin u r missing some setting in ur driver.
else reinstall the driver
Posted on Jun 16, 2008
Not Enough Memory Canon DR 4010C
There is no 'User memory' in Dr 4010C. The memory available is sued as a buffer for processing scanned images. You need to have 'memory' i.e., storage space in your harddisk. If you are scanning in Color, you need larger space.
S. Mohan, Chennai, India
Aug 29, 2011 | Canon DR-4010C
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
I cannot scan more than one page at a time.
The scanner can only scan one at a time, if you can't scan multiple pages you need to adjust the scanning software and settings, not the printer or scanner.
Aug 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannonc DR4010 c pulls thru all the pages at one time- it does not pull individually-
This is clear roller problem. Clean the rollers thoroughly witha damp cloth. The ****** rollers should ideally be cleaned in power-off mode. This should solve paper feeding problems. Check if the pages are dusty.
The rollers last for about 250,000 scans. If it has crossed this number, you need to change them.
Jul 20, 2009 | Canon Office Equipment & Supplies
How do I add multiple pages to one scanned doucment?
Open your Adobe Acrobat (e.g., 9.0 Pro), load your pages into the document feeder (fewer than 30 at a time), then ask Adobe Acrobat to create PDF from scanner (File/Create PDF/From Scanner). Canon MP530 as the scanner and click OK. Works like a charm!
Jul 07, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Jun 26, 2009 | HP Photosmart C5280 Printer
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
Scanner can't scan multiple papers by itself.
Ensure the rollers are clean. Clean with with a damp cloth or with IsoPropyl Alcohol (IPA Industrial Grade). Dont use solvents. Check if the papers are sticky. Sometimes stapled documets are held together at the point where is it was stapled. The small 'depression' is enough to hold two papers together.
Jan 14, 2009 | Canon DR 3080C Path-Through Scanner
Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
Nov 26, 2008 | Canon DR-2580C Path-Through Scanner
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Feb 06, 2008 | Office Equipment & Supplies
183 people viewed this question
jasbo
jasbo
