Question about Sansui DTV1300 TV
Need a Q402 numbers on part C6085( Regulator) need a correct part number
On the 1967 sears super 12 tractor what part number replaced sears part number 606A190 for the voltage regulator
you have a starter generator... you can go to most specialty 12 volt shops ( starter re-builder ) or online and find a good quality universal V.R. can't remember if thats a 6 or 12 volt system... google 12 volt external voltage regulator and you will get an idea what I am talking about. I've done this repair a number of times
Oct 23, 2014 | Garden
Need a control knob for : dyna-glo pro propane heater. model # rmc-tt 30dgp-01, # rmc-tt30dg, #rmc-tt30gd. serial: # 09 005720
Contact GHP Group Inc, (877) 447-4768 to order a replacement regulator - MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Replacement cost including shipping is a couple bits over $21.
When talking to the technician on the phone, he cautioned me against rapidly opening the tank valve, which hammers the regulator (the replacement one is more robust than the original), kinda' like how water-hammer can cause damage to water pipes and/or water appliances. Open the tank valve gently, don't just whip it open (like I used to), your regulator will last a lot longer that way.
Because of the press-fit and pins used in the regulator construction & assembly, self-repair is not possible or recommended since the regulator may not seal correctly afterwards.
Dec 17, 2010 | Garden
Hi I am trying to convert my Dacor stove/oven from NG to Propane. We can't find the conversion kit anywhere. Any ideas?
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
Jan 29, 2010 | Dacor Preference SGM365SS Gas Cooktop
Passenger window fails to go up the last 1/4 inch. How do I remove the interior door panel and what am I looking for? Michael
Hello Michael. I am surprised that your window continued to work well as long as it has. Most haven't. This is a common issue with 1999-2002 Sonatas. You'll either need to replace the regulator upper holder or the regulator itself.
Technical Service Bulletin (TSB) 02-80-001 provides very nice details for replacing either the regulator upper holder or the regulator itself. You can view the TSB at www.hmaservice.com (requires Internet Explorer) by signing up for a free account.
The part numbers are as follows:
left front holder: 82430-38000
right front holder: 82440-38000
left front regulator: 82403-38011
right front regulator: 82404-38011.
I copied the part numbers from the TSB. If memory serves, the regulator numbers ending in -38011 may have superseded to numbers ending in -38012.
Regards, Joe PS please rate my answer. Thank you Michael and happy holidays.
Dec 16, 2009 | 2000 Hyundai Sonata
I need a new regulator with a low med high knob for two burner dyna glo tank top heater propane if tou have how much if not where can I get one thank you
If you don't have an authorized dealer to get a replacement regulator, contact GHP Group Inc, (877) 447-4768. MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Here's a link to the manual for eight of their tank-top heaters
Nov 20, 2009 | Grilling
NO DISPLAY
try to check all components (smps section )
Apr 08, 2009 | SAMTRON 55V 15" CRT Monitor
15" CRT Monitor samsung totally dead
Dear munu007 good morning this is viswanath
Don't worry I can salove UR problem
1.First U can check any physical damage in power supply (220/400v)Main capacitor,
2.And also check LOT It's OK Than Remove H O/p Transister, check SMPS output voltages ,voltages are currect That means SMPS is OK.Check Boosting FET IRF630(Q402)Change it New One,and also change the IC604 7805 Regulator.
Finally change LOT.
check any dry points (SMPS&Hori.)
Oct 08, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Television power led blinking
are you sure that you are checking this correctly?
What is the location number for this regulator?
If its the main regulator, what are you using for ground on your meter? Also, isn't the part number marked on the regulator?
Apr 12, 2008 | Toshiba 27DF46 27" TV
Sansui DTV1300 TV Logo
66 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
