Question about Whirlpool Dishwashers
Have a Whirlpool built in dishwasher, it's electronic. It has two soap dispensers; one open and one with a latch cover. The latch cover fails to open in the second phase of the wash. Can you give me a clue as to what is happening?
  • 1 more comment
  • jhn_sepulved Nov 09, 2010
    Here's the model #DU920GWDG4 Model series 920 The letter in the model # could be a V instead of a U.
    Dishwasher has completely drained after the second phase
  • jhn_sepulved Nov 13, 2010
    replacing soap dispenser
    President:
  • 1,891 Answers
X sure / the dispenser open in the main wash if its working . and it sounds like is not . only thing you can do is replace the soap disp . very common prob . mm hope this helped . feed back pls ..
Posted on Nov 10, 2010
  • Whirlpool Master
  • 3,247 Answers
It would be helpful to have the full model number of the whirlpool dishwasher.
Is the second phase of the wash actually complete? Is the dishwasher completely drained out when the 2nd phase of wash is finished?
Posted on Nov 09, 2010
  • 1 more comment
  • Sam Nov 09, 2010
    please respond to the second part of my query to you. Thanks for providing the model number.
  • Sam Nov 10, 2010
    In that case it appears the cycle is completing but the detergent dispenser door is not operating.
    Possibly a stuck solenoid or spring. Need to get into the door and check it out.
    See this diagram for details. Item 4 is the actuator. Hope this helps.
    Please rate the solution if ok else post a comment so that I can help you further.
  • Sam Nov 13, 2010
    Post me a comment to confirm when you replace it.
    Also accept the solution if ok. cmmiuser01
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Soap dispenser cover latch will not stay in the hole. So now the soap holder will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My older model whirlpool dishwasher soap dispenser cap wont open...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Oct 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have Whirlpool model DU1145XPTBA and the detergent will not dispense during cleaning. I have checked the door and the spring latches easily, and there is absolutely no detergent build-up. Any...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101
Aug 31, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
My FDB1050REC0 soap dispenser doesnt open
More than likely it's the dispenser that's faulty. They use a wax motor to open the dispenser, which is prone to failing. I'd order the dispenser, then you remove 2 phillips screws that hold your front panel on, then you'll see the 6 screws that hold the dispenser in place.
Mar 30, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Closed soap dispenser won't open during wash cycle
check if its not gumed up. manually open it with latch under neith
Feb 11, 2010 | Whirlpool GU2400XTPS Built-in Dishwasher
Whirlpool Gold Quiet Partner IV issue with soap dispenser
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Dec 05, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Nov 26, 2008 | Bosch SHU9925UC Built-in Dishwasher
Soap dispenser does not release
I found out for FREE on another sight. I'm replacing my timer.
Nov 09, 2008 | Whirlpool 24 in. DU920PW Built-In...
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
180 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
