Question about Ovens
Hi ive got a er08 code on my hotpoint bs73e - Ovens
My hotpoint bs73e wont heat up when i turn the dial
make sure the outlet has power first!!!!!!!!
check for a fuse, the fuse will be inside the unit right where the plug connect is located, you are going to have to remove some screws open the unit, check the wiring, check the element, if all okay call a service repair person or call the manufactures customer service line. look in the FAQ section for other issues
Sep 17, 2015 | Hotpoint Ovens
I'm getting an beeping and a flashing F2 signal on the display. What is that?
this means an overtemperature condition.
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Hotpoint%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes
There are two conditions for this, but both of them look like they require replacement parts.
a repair tech will need to be called. 1-800-4MY-HOME is Sears. They are a bit more expensive than some. Alternatively search the HotPoint Web site for authorized repair techs.
Sincerely,
Mark
Apr 01, 2011 | Hotpoint Ovens
Ariston FZ 970 CI IX The display is flashing Er 08. Can I repair this, cooking tonight John
Hi, does anyone know how to fix the problem when my ariston oven display appear Er08, thanks to advise asap!!! cheers
Nov 04, 2010 | Ovens
Have an older model Hotpoint stove model number KS947MW-1. Get an rror code of F3 when trying to turn oven part on.
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Hotpoint Ovens
Hotpoint oven will not light
Here is a tip that I wrote about this problem...
Check it out here...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 09, 2010 | Hotpoint Ovens
What does ER08 mean
Hi, It indicates an overheated pcb board. This is a job for Creda as there are various causes and you could be buying expensive parts for nothing! :(
Jun 25, 2009 | Creda Ovens
HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Nov 23, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint stove fuse confirguration
Remove the old ones ONLY if you know what you are doing, and take them to the parts place with the modl # and serial # found on the tag plate!
Sep 06, 2008 | Hotpoint Ovens
Hotpoint sy51x oven
your thermostat is on its way out it is place on the other side of the knob you will need a oven engineer to have a look
Jan 04, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Oven door locked
if the oven cooled down and door still wont open unplug oven for 15minutes and see if that helps ive seen in many cases were the door had to be destroyed to gain access to the oven
Dec 30, 2007 | Hotpoint SY21 Style Line Gas Single Oven
Ovens Logo
158 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
