Question about Brother GX-6750 Typewriter
I have replaced my correction tape several times, and have never had a problem. Now this time, it is not coming up high enough to correct (looks like anyway). GX-6750 thanks, N
  • Brother Master
  • 3,594 Answers
Be sure that it is a dry L/O tape not tacky they will give you fits.
DickyO
Posted on Nov 11, 2010
Wheelwriter 2 correction ribbon lift adjustment nost high enough
Check that the lift off is properly attached to the ribbon and ribbon is installed properly, If the liittle tabs on the L/O cassette are broken you can use a piece of tape to hold them together.
DickyO
Apr 10, 2013 | IBM Lexmark Personal Wheelwriter 2...
Water pump went out order new one ,it look like imay halt todis assembl rhe right side of motor to even get it ,including my timing belt
That is correct. The timing belt must be removed to replace the water pump.
CAUTION: Your vehicle is equipped with an "interference engine", meaning that if the timing belt is not replaced properly, or if the engine is not timed correctly, or if for any reason the timing belt breaks or comes loose, SEVERE ENGINE DAMAGE CAN RESULT.
Aug 27, 2011 | 1997 Mitsubishi Mirage
Installed a Graphics Card on my Emachine. Made sure it is in the PCIX slot correctly and seated right. I also installed a Power adapter cable (20 PIN - 24 PIN ATX) to utilize the other 4 pins for use with...
Sounds like there isnt enough power even with the adapters your powersupply cannot give you enough sustained power to run the system if you take the card out does it boot normally? even just disconnecting the power to the card?
Mar 26, 2011 | E-Machines W6409 (7234) PC Desktop
Timing tensinor replace
The entire front of the engine must be disassembled to replace the timing belt tensioner. Your vehicle is equipped with an "Interference engine" meaning that if the timing belt/tensioner is not installed correctly, or if the timing belt breaks or comes off of the pullies, severe engine damage will result.
Jan 29, 2011 | 2002 Hyundai Accent
Typewriter won't erase letters completely.
Correction tapes do have a shelf life and can dry out. You should try replacing the correction tape and see if it is better. If that does not fix it, does the tape lift up high enough to cover the entire letter? If not, you have a lifting problem and will need a tech to fix it.
May 28, 2010 | IBM Wheelwriter 6 Typewriter
How to change the correction tape
There are two levers on the right side of the carrier for the typewriter and correction ribbon. The little red lever close to the front right corner is to release the typing ribbon. the larger grey lever on the right end of the ribbon mounting bracket releases the correction tape. Pull it to the front, and it will release the correction tape. Look welll to see how the ribbon is threaded through the spindles and behind the guides next to the platten roller, before you take the old correction roll off.
NOTE: When changing either typing or correction ribbon, you need to know that only one of the levers mentioned will release at a time. If you have released one, you will have to snap it back into working position and pull the other lever to release it. THEY absolutely will not both release at the same time.
Feb 11, 2010 | Nakajima AE-830 Typewriter
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
Smith corona 4500 pwp pluse install correction tape
There were two types of correction tape used on these machines. I believe your's uses the two spools. Before you do anything, look at the old ones on your machine and follow along with how it was installed. The full one will go on the left, and the empty on the right. It will feed through a couple of metal prongs I believe. There then is usually a red lever under the spool on the left. click it several times and it will tighten it. (especially true of the cartridge type).
Oct 08, 2009 | Smith Corona Wordsmith 100 Typewriter
Brother EM-601
I am sorry to say that that is an indication of a worn out lift gear. It is a common repair if you can find a “Brother Authorized” service center it shouldn’t be to expensive. But it’s time to dump the typewriters and go with PDF that can be filled in.
Feb 29, 2008 | Office Equipment & Supplies
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother GX-6750 Typewriter Logo
178 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
