Question about Canon PIXMA MP240 All-In-One InkJet Printer
Scanner doesn't work - Canon PIXMA MP240 All-In-One InkJet Printer
  • Canon Master
  • 12,061 Answers
You most probably need to install/re-install the printer/scanner software and scanner manager.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#DriversAndSoftware
Above please find your canon drivers, download these and install as Administrator...also make sure you install the scanner driver as well as the printer driver...also you need a Scan manager too..
If you have installed the scanner before you need to remove it from device manager, by removing the drivers. Once that's done, unplug the printer. Then reboot,.(If you have a CD/DVD that came with the unit, you can and should use this, else download the files from the link given) Then install the new software now do NOT connect the device, only connect when/if asked, or at the end of the install and after a reboot, then, plug in the printer/scanner.
It should be detected and install itself, it may ask for drivers if so, show it where they are, and it should proceed and you should now be able to scan and print, now you must use a scanning program, and or the interface that came with the unit, Canon Scanmanager, however, if installed correctly you can also scan into Mspaint, Word, Publisher etc. but there are many free scan manager programs on the 'net. a good one is Vuescan, http://www.hamrick.com/ now the beauty of this program is that is doesn't require any "Drivers" as it has it's own, so as long as the scanner physically works, then this program will scan with it.
Another is Freekapture ,http://www.freewarefiles.com/FreeKapture_program_32165.html
This uses TWAIN drivers, that should install at the same time.
http://www.ehow.com/how_2006169_troubleshoot-scanner-printer.html
http://www.tutorialsweb.com/computers/printers-scanners/Tools-to-troubleshooting-printer-scanner-problems.htm
Above are a couple of DIY sites to help also.
Posted on Nov 08, 2010
    President:
  • 2,571 Answers
Not alot to go on here.
Try reinstall the software.
Does it copy when you use the copy button on the printer?
MC 9190 LongRange scanner
It looks like the backup-battery is empty
May 29, 2013 | Zebra Symbol Technologies MC909X-G Series...
I have HP SCANNER G2410 ."tak tak" sound on
Just a guess, may be you have not unlocked the scanner.
On the bottom side there is lock for transporting the scanner. Turn the scanner upside down and check. Put it into the unlock position.
As I said it is just a guess. If this doesn't work, let me know.
Sep 23, 2011 | HP ScanJet 2400 Flatbed Scanner
I installed a printer on my PC and the scanner does not work. Should i install the scanner aswell?
Do you have the combo printer that comes with scanner and printer in one machine? If you do, then one installation should work the device as the computer will recognize it as one. If that's what you have, and the scanner still doesn't work, return the machine and ask for a new one.
If you have separate scanner and printer machines, then you should have two installation discs as each should have its own. You will need to install the scanner if this is the case.
Hope this helps.
Aug 30, 2011 | Office Equipment & Supplies
I have an hp psc 750 and the scanner doesn't work or won't work I need help to get it working,
you have to open the top cover and clean the scanner mirrors in the scanner unit.
Aug 04, 2011 | HP Office Equipment & Supplies
I have updated my computer to a Windows 7 version and my PrimaScan Colorado 2600u driver does not seem to be compatible
Hello, I've looked around on the website and there doesn't seem to be a driver for this device to work on Windows 7. It doesn't support this operating system, sorry.
You can either downgrade to Windows XP or get a new barcode scanner.
Jul 09, 2011 | Visioneer PrimaScan Colorado 2600u Flatbed...
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Computer doesn't recognize scanner
maybe the cabel is broken, what type of cabel do you use for connecting to pc? if usb try to change the usb port, if this doesn"t work change the cabel. btw the scanner has to be started.
Dec 15, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
680 people viewed this question
old marine
old marine
