Question about M-Audio Fast Track USB (FASTTRACK) Audio Input
Two questions: #1: Fast Track often disconnects. Go System Pref/sound and click on "Sample Rate". Always comes back but a drag. #2: Continuous hi freq (about 1000k) unless gain is kept low. Is always there as long as my computer routes sound out thru FT. Running MAC 10.6.4 and 10.4.11. Same thing either way. Thanks
  • krkorte Nov 08, 2010
    Ok, I don't use Bluetooth or Airport & the Fast Track is already 4 ft away. The aprox 1000k sound is always there, recording or not and it does show up on recordings as well. I have enough head room to usually keep it under control but sometimes with a low signal level, you can still hear it.
  • krkorte Nov 09, 2010
    Will try some of your suggestios
  • 7,733 Answers
To alleviate this problem, try moving your M-Audio device a short distance away from your computer. Another solution is to turn off Bluetooth and your wireless network and / or airport card during the recording. If you have a cell phone, move it away from your speakers and M-Audio interface.
Limited bandwidth of the USB 1.1 bus:
- 2 Inputs and 0 Outputs at 24Bit / 96kHz
- 0 Inputs and 2 Outputs at 24Bit / 96kHz
- 4 Inputs and 2 Outputs at 24Bit / 44.1 or 48kHz
- 2 Inputs and 4 Outputs at 24Bit / 44.1 or 48kHz
- 4 Inputs and 4 Outputs at 16Bit / 44.1 or 48kHz
- 2 Inputs and 8 Outputs at 16Bit / 44.1 or 48kHz (Sonica Theater)
- 4 Inputs and 4 Outputs with every other sample rate up to 16Bit/44.1kHz. This information applies to recording/playback through separate physical Inputs and/or Outputs. Of course you can't get more inputs or outputs than physically present on your USB Audio device. Playing multiple audio tracks that are mixed down within a software application and being output through the available physical audio outputs on the M-Audio USB audio device is always possible (e.g. playing a virtually unlimited amount of audio tracks within a software application, played through the outputs 1+2 on the USB audio device). Some M-Audio USB audio devices do not support all listed Sample Rates and/or Bit Depths (e.g. MobilePre/FastTrack up to 48kHz, Black Box always at 44.1 kHz).
For USB devices equipped with an power button or switch, power off your M-Audio device before putting the computer in sleep mode, and wake the computer from sleep mode before powering your device back on.
For USB devices without a power switch, disconnect the USB cable before putting the computer in sleep mode, and wake the computer from sleep mode before reconnecting. You can disconnect the USB cable from either the M-Audio device or the computer. When disconnecting from the computer, make sure you reconnect to the same USB port.
If your M-Audio device is not working after following the procedures above, restart your computer to re-establish a connection with the device.
Posted on Nov 08, 2010
  • Doctor PC
    Doctor PC Nov 09, 2010
    Did you try those fix?
  • Doctor PC
    Often times these problems are a result of system
    performance. Increasing the Buffer Size for your M-Audio device will
    help alleviate the processing demands placed on your CPU. In OS X, this
    setting is adjusted from within your recording application. This
    setting is generally located in the Preferences Menu in an audio
    configuration menu. Please refer to your application's user guide to
    find out how to change the buffer size. Try increasing by small
    increments and then test the audio quality again.
    Repair your Disk Permissions:
    1. Open the Utilities folder located in Macintosh HD>Applications >Utilities
    2. Double click to open Disk Utility
    3. Select your Macintosh HD
    4. On the First Aid tab click Repair Disk Permissions
    This may take a few minutes; it is a general maintenance routine for the OS, and important to ensure the proper functioning of MIDI and audio. When the permissions repair is complete you can quit the Disk Utility.
    Bluetooth and Airport Wireless have been known to cause problems with
    pops, clicks, and distortion during recording and playback. Disable
    both of these from System Preferences and then test the audio quality
    again. These devices can easily be activated when needed.
    MacBook and MacBook Pro users should verify they are connecting their M-Audio USB interface to the recommended USB port. Specific USB ports on these systems are known to cause pops, clicks, and dropouts in the audio.
    MacBook 13.3" recommended USB port
    MacBook Pro recommended USB port(s)
    Is your Operating System up to date? Since we have seen problems after
    using the Automatic Software Update to update the OS, we always
    recommend downloading and installing the "Combo Update". Installing the
    combo update is recommended as a troubleshooting step and ensures that
    all system files are up to date. This combo update can be installed on
    top of your existing OS without having to reformat and lose any files.
    For example, if you are using OS X version 10.5.5, go to http://www.apple.com/downloads
    and search for "10.5.5 combo update". Save the appropriate file for
    your exact OS version to your desktop. Disconnect your M-Audio USB
    device before installing the combo update. Once the combo update
    is installed repair disk permissions (see above), then uninstall and
    re-install the latest M-Audio driver and repair disk permissions again.
    Often times these problems are a result of system performance. Increasing the Buffer Size for your M-Audio device will help alleviate the processing demands placed on your CPU. In OS X, this setting is adjusted from within your recording application. This setting is generally located in the Preferences Menu in an audio configuration menu. Please refer to your application's user guide to find out how to change the buffer size. Try increasing by small increments and then test the audio quality again.
    Bluetooth and Airport Wireless have been known to cause problems with pops, clicks, and distortion during recording and playback. Disable both of these from System Preferences and then test the audio quality again. These devices can easily be activated when needed.
    Is your Operating System up to date? Since we have seen problems after using the Automatic Software Update to update the OS, we always recommend downloading and installing the "Combo Update". Installing the combo update is recommended as a troubleshooting step and ensures that all system files are up to date. This combo update can be installed on top of your existing OS without having to reformat and lose any files. For example, if you are using OS X version 10.5.5, go to http://www.apple.com/downloads and search for "10.5.5 combo update". Save the appropriate file for your exact OS version to your desktop. Disconnect your M-Audio USB device before installing the combo update. Once the combo update is installed repair disk permissions (see above), then uninstall and re-install the latest M-Audio driver and repair disk permissions again.
I want to fix itunes in my cell
1. Insert the driver installation CD into the computer, then wait for the installation wizard to load onto the screen.
2. Click "Next" on the welcome page, then follow the prompts of the installation wizard to completely setup the driver onto the computer.
3. Plug the USB data cable into the power port on the side of the Motorola RAZR V3 cell phone. Connect the other end into any USB port on the computer system.
4. Click "Start," "(My) Computer," then double-click the removable device icon. Select the "Music" icon to load a window with all the music saved on the cell phone.
5. Click-and-drag the music from your computer into the open window. You are able to copy over any audio track from a system media player, such as Windows Media Player or iTunes (open the program, then click-and-drag a track into the window). Repeat this process with any other audio file.
6. Close out the open windows, then right-click the removable device icon and select "Eject." Disconnect the Motorola RAZR V3xx from the computer once the icon disappears.
Aug 19, 2012 | Motorola Mobility RAZR V3i Cellular Phone
Tip
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions<br />1.<span> </span>GeneralTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume). <ol> <ul> <li>2 </li></ul></ol> Unplug any headphones that might be connected toyour computer's headphones port. If your <a href="http://www.ehow.com/computers/">computer</a> has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers. <ol> <ul> <li>3 </li></ul></ol> Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly. <ol> <ul> <li>4 </li></ul></ol> Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2.<span> </span>GaragebandTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments. <ol> <ul> <li>2 </li></ul></ol> Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action. <ol> <ul> <li>3 </li></ul></ol> Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.<br />Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again. <ol> <ul> <li>4 </li></ul></ol> If any of the previous steps do not fix the soundproblem, reboot and try again. <br />If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
on Jan 21, 2011 | Computers & Internet
My logitech z-5300 speakers were working perfect to play itunes & sounds from all programs. Got video camera & tried to use it but no sounds played around in control panel now my speakers wont...
Hi
You do not say which operating system you are using. My answer can therefore only be general rather than specific to your operating system.
The Video Camera you tried to install probably has an in-built microphone. Connecting this is may have changed the default settings for your audio devices.
You have a number of options for fixing this problem.
SYSTEM RESTORE
Start > All programs > Accessories > System Tools > System Restore > Restore my computer to an earlier time > selected a highlighted date in the calendar and an Event in the schedule before the date you tried to install the video camera > restore > restart the computer (you should hear the windows logon on tones if you are using a windows operating system) > (My) Music > Sample Music > double click on any track to test the sound playback.
AUDIO SETTINGS
Start > Control Panel > Audio devices > Audio (Playback Devices) > Set Defaults (set the Speakers to be the Default Playback devices > apply > ok > restatrt computer > (My) Music > Sample Music > double click on any track to test the sound playback.
AUDIO/SOUND DRIVERS
Reinstalling the Audio/Sound Drivers would also probably resolve the problem by restoring your Default Audio settings, if you have the Driver CD for your Laptop or Desktop Motherboard > install Audio/Sound Driver > restart computer > (My) Music > Sample Music > double click on any track to test the sound playback.
I cannot direct you to a driver download site, because you have given no information about your computer.
If this answer helps you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and helps us explore the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Aug 31, 2011 | Logitech Z-5300 Computer Speakers
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
How Do I Capture Live Audio with M-Audio Fast Track Pro
All you have to do is to connect with 2 cables your cd's or dvd's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Stelios
Aug 31, 2008 | M-Audio Fast Track Pro Mobile USB...
Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
Mar 13, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
M-Audio Fast Track USB (FASTTRACK) Audio Input Logo
555 people viewed this question
Top M-Audio Televison & Video Experts
Paul Bade
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
