Question about HP Deskjet F4180 All-in-One InkJet Printer
Printer is nprinting in appropriate color - HP Deskjet F4180 All-in-One InkJet Printer
  • HP Master
  • 7,733 Answers
How can I alway print in black. I do not want to print in color
Open the printer settings from the control panel and set the printer preferences from there.
You can also click start menu, then click printers and faxes on the computer onto which the printer is installed. When the list of printers are shown, right click on the printer whose settings you want to change. Select printing preferences. Select the printing color settings set appropriately.
Apr 22, 2011 | Dell 1320c Laser Printer
The color does not print anymore, only the black thank you, jacques los angeles
Printers usually have two separate ink cartridges. Depending on the cartridge that is over exerted in print jobs is depleted faster than the remaining one. Open the ink compartment to ascertain the ink models to make possible acquisition for replacement from retail. Ink acquisitions may require verification for the appropriate models and brands. Extracting the depleted ink cartridge as reference comparison at retail enables appropriate ink selections compatible with the printer.
Feb 02, 2011 | Lexmark Z615 InkJet Printer
I just installed one of the so called profesional color ink cartrige refills on my dell printer and it will only print blue. Do you have any suggestions to open the rest of the colors
Head cleaning is always an option. Your software should install a toolbox in your printer properties.
Asuming you have WinXP or Vista... just go to start, printers and right click on the appropriate printer and click properties. You should find head cleaning there somewhere.
Oh, and also check the expiry date on the cartridge box; might be that the cartridge is dry.
Jul 07, 2009 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
How to print in color only
Go to the Control Panel -> Printers & Faxes. Select your printer an Right Click -> Properties. Select the appropriate option. Secon method is more easy. Create all of your documnts in colors.
Jul 06, 2009 | HP DeskJet 932c InkJet Printer
THE ORANGELIGHT ON FRONT OF CANON 1P4200 PRINTER FLASHES SEVEN
From manual:
Seven Flashes: The ink tank is not installed in the appropriate position
Possible causes are as follows:
Some ink tanks are not installed in place.
More than one ink tanks of the same color are installed.
Confirm that the ink tanks are installed in the appropriate positions.
Jun 09, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Will not print in color brother mfc-665cw
Check to see if the ink color is installed correctly....if it is installed correctly...then you may right click on the printer name in the printers menu...choose properties and look for where it says print in color or black and white and chose the appropriate one as you desire..
Mar 26, 2009 | Brother Multi-Function Center MFC-665CW...
How to refill Brother printer cartridge for model MFC 240C Cartridge # LC51BK
hi , Do this Pop-off the color top, removed the clear rubber ball ring/valve. Now you can usual refill kit to poor in the appropriate in color. After filling the ink,replace the above two in reverse order and taped down with clear type. Replaced the cartridge and the appropriate slot... and your good to go! be carefull, sometimes they do leak....
Jul 27, 2008 | Office Equipment & Supplies
HP Deskjet F2180 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
If you are looking at the cartridges the black is on the right color is on the left. photo=color.
Thanks and I hope you find this appropriate for a FixYa rating,
Lee
Jun 19, 2008 | HP Office Equipment & Supplies
Always used hp tri-color print cartridge in in my hp psc 2355 all-in-one printer. Has stopped working. Says printer has wrong tri-color cartridge inserted
Check manual for appropriate cartridge class for tri color and use same numbers as in manual you may be using 22 cartridge for 28 for example for your printer this cartridges look the same in all aspects but some HP printers can only be used by only one of this types. Check printer manual for compatible ink cartridges. And if you have been refiling the old cartridge you need to get a new one to reset the computer cartridge memory count.
May 30, 2008 | HP Office Equipment & Supplies
Cannon IP 90 Printer
Your tech suggested that I remove both of the ink tanks (black & color) and turn off the printer and then re-start the printer.
After I did that, there was no futher problem, and the printer worked fine with appropriate colors.
Feb 23, 2008 | Office Equipment & Supplies
HP Deskjet F4180 All-in-One InkJet Printer Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
