Question about LaCie Grand 1 TB USB 20 Hard Drive
The lacie grand 1 tb usb hard drive will turn on but it's logo is not appearing on my desk top and I can't access any of my files from it. Any ideas?
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Posted on Nov 10, 2010
How to recover password from LaCie 1TB Rikiki USB 3.0 Portable Hard Drive
ga naar lacie.com and probeer
Support & Downloads
Frequently Asked Questions pfp.gif Printer Friendly
Configure Your Drive Using the NAS Administration Page
Accessing The NAS Administration Page
    There are two ways of accessing the NAS Administration page, Using the IP Configurator Wizard, and Using the Browser.Using the IP Configurator Wizard
May 04, 2014 | LaCie 2big Quadra 3 TB Spare Drive3 TB...
Accidentally reformatted now data inaccessable
I'm afraid you've lost all of your data. Next time use a separate External USB Hard Drive or a USB Flash Drive for that kind of process. But, go back with the drive to the original desktop and see, maybe everything is still there and the other PC did not see it/touch it, hope so. Good luck.
Jan 03, 2018 | LaCie Grand 1 TB USB 20 Hard Drive
LaCie Hard Disk USB 2.0 1 TB i lost the power
this unit is compatible with a few of LaCie power supplies, but it is generally sold with the one providing hte following:
DC Output: 12V (2A) 24W
Regards,
Jan 19, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My lacie rugged hard drive can no longer be found in my computer (Widows) even though my device/disk manager can detect it and its location is said at "location 0" and I cannot reassign a new...
Hi
try to check your hard drive on other computers and see if you could access your files or not.
1-other computers can detect your HDD:
1-1-software issues on laptop:
try to update windows or OS of your computer for most updated driver
1-2-hardware issues on HDD:
1-2-1:you have a broken/shacked/shocked/stroke HDD:
go for replacement or warranty service.
1-2-2:USB/fire wire cable problem:
replace it
2-3:you have a damaged/weak USB port on your laptop that couldn't fully supplied the minimum needed current:
repair the damaged port via certified expert or manufacturer warranty/repair service.
2-other computers can not detect your HDD:
2-1:cable problem
2-2:you have a broken/shacked/shocked/stroke HDD:
best regards
Oct 04, 2017 | LaCie Rugged Hard Disk hard drive - 301924...
I just bought my LaCie 301888KUA 1TB Starck Desktop USB2.0. I was following set up directions in the manual until I realized that my Mac OS X (version 10.5.8) is not recognizing the hard drive . It's not...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie 301888KUA 1TB Starck Desktop 1 TB...
Won't recognize drive
Have you checked the disk properties to see if the 400 GB of data is still showing. may be your data might be hidden foir some reason. can you give more details pls
May 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
LaCie 1 TB Hard drive won't boot
I lave lots and lots of experience with LaCie Drives (I have 6 of the 2TB models). Every, every, every time a drive fails or runs slowly, it is the power supply. I have now replaced 5. They run very hot (so does the drive), and fail pretty often. It looks like the voltage drops just a smidge, and access times seem to increase, i.e., the drive "runs slow". Then it won't boot at all, and the blue light keeps blinking. Fortunately LaCie has replacement power supplies in the store. Buy a couple extra. I am married to the LaCie drives now, or I would probably switch brands. I kind of guess that they know about this because I contacted the help desk, and he wasn't surprised. Maxtor has a nice drive, and the Calvary drive is $150 cheaper. A drive is a drive I guess. By the way, if anyone is listening, how about building a QUIET, COOL drive with and INTERNAL POWER SUPPLY? GOT IT? All the cords and power supply bricks make me crazy. It might be nice to see a stackable drive where the top of one drive mates to the bottom of another, carrying network info as well as power to the drive above. Hint, hint. We all are building systems with ungodly amounts of storage. Too bad the manufacturers aren't building drives with the durability we need.
Oct 08, 2007 | LaCie (301074) 80 GB Hard Drive
LaCie Grand 1 TB USB 20 Hard Drive Logo
268 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
