Question about Remington Sport & Outdoor - Others
1100 will not **** . remove barrel and it will **** and can be dry fired
  • km11 Nov 09, 2010
    PLAIN AND SIMPLE IT WILL NOT **** WITH THE BARREL CAP TIGHTENED REMOVE THE BARREL FROM THE ACTION COCKIT AND IT WILL DRY FIRE I CANT FIGURE IT OUT ALL PARTS ARE THERE THE REMOVED TRIGGER GROUP CAN ALSO BE COCKED AND DRY FIRED
  • 2,382 Answers
Please re-post you question so it can be properly understood and answered...
Posted on Nov 08, 2010
The gun will not fire. What should I look for?
Clean it first then check to see if the firing pin is broken.
Dec 07, 2015 | Optics
My cordless Dewalt finishing gun has stopped firing when you try to fire it in a vertical position. Works fine on skirting and architrave but just gives a little 'pop' if try to fix anything to ceiling.
is this a gas cartridge type of nailer? It could be the effects of gravity on the spray nozzle. try pushing down in normal position but dont fire it. quickly move to ceiling then try firing. I am not a fan of this type of nailer as they are problematic and finicky.
Jan 23, 2015 | Dewalt Tools & Hardware - Others
How do I tighten/ secure the barrel to the stock of my Beeman R9?
Has the stock dried out or the stock screws coming loose
Has the stock to action gap gotten larger if so you could try getting the synthetic stock
Sep 07, 2014 | Beeman R9 Air Rifle, No Sights - 0.177...
HOW DO I REPLACE IGNITION SWITCH & BARREL ON UNO 1100
never post emails , you will now get 10,000 spam a day, wow.
sorry !
it can be easy or hard, but in general its:
just the barrel tumbler, ?, that is locked on back side on purpose.
pull battery neg lug. (no fires please) or blown main fuses.
defeat air bags , via method stated in FSM. (DANGER big time)
1: remove covers from switch section, there, screws below.
2: remove headless antitamper screws on ignition switch clamp
3: the whole assemby is free.
4: on 1/2 the cars the steering wheel needs to be remove, painfull that.
disconnect its connector now or at step 1.5.
the tumbler pin is on back side, ask any lock smith to fix this.
he has the special tools needed.
Jul 15, 2014 | Fiat 1100 Cars & Trucks
Remington 1100 wont eject or load another shell
check and see if the shell stop hasn't broken loose. this on the inside left side of the action . this could stopping the next shell in the mag. from being loaded. this not uncommon. but is an easy fix. a gun smith can stake it back in . in a few minutes for around $20.00
Nov 25, 2012 | Remington Shotgun Mount 12Ga Lh, B Square...
How do i clean a springfield model 67e 20 ga shotgun? I do not see an easy method of removing the triger mechanism.
dont,,,,just dont,,, remove the triger and you should never oil a triger any how, it could cause them to fire off when you least wont them to,,and bullets kill you know? so its realy is best not to take the triger to bits,,,i give mine a quick splash of wd40 every 5 years or so??? or after 3000 rounds have been fired
just cearfully swob the barrel out and dry it well then oil the out sides and the wood work, job done then
Nov 20, 2009 | Optics
My daisy model 99 bb gun does not shoot bb's with any force.
Try shooting a ton of silicone oil into the oil hole on the side of the barrel and then leave the gun sitting on its muzzle over night, then in the morning with the barrel out dry fire it a couple of times and then try it. what this does is expand the leather seal and bring back air pressure. it worked on my 99, good luck
Mar 23, 2009 | Sport & Outdoor - Others
Remington 1100 12 gage won't load a shell from the magazine
Are you shooting very light load?
Have you tried different ammo?
Light loads may not produce enough energy to work the action properly.
If different ammo doesn't help, make sure the two holes inside the barrel ring are clean and gas from the barrel can pass through. Next I would check the o-ring for cracks. If you shoot lots of shells (competition clays) the recoil springs inside the stock or over the magazine tube may have become weak and need replacing.
Jan 12, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Removing plug
remove forecap and barrel. Carefully because magazine spring and follower could pop out. Shake gun back and forth and wood dowel (plug)should slide out
Sport & Outdoor - Others Logo
Top Remington Sport & Outdoor - Others Experts
steve morris
steve morris
 steve
steve
Tom Chichester
Are you a Remington Sport and Outdoor - Other Expert? Answer questions, earn points and help others
