Question about Western Digital Computers & Internet
I have a Western Digital external hard drive (MyPassport Elite) and it has stopped recognising it. I recently got a new laptop with Windows 7 after my last one with vista broke. It worked fine for the first two days and now it won't let me access my files. When I plug it in, no lights appear but the disk inside is spinning, then it stops spinning and the lights start to flash and at this point it is recognised on my laptop but I can't access it to get my files.
  • oliviathom Nov 08, 2010
    I just tried it with the original cable and the problem is persisting. I've been using a different cable for months with no problems and the original cable provided doesn't always work (which is why I changed cables).
    Thanks for your solution though!
  • Western Digital Master
  • 3,287 Answers
Make sure you're using the cable supplied. I have a Passport Drive that came with a 6" cable which I found to be too short. When I used a longer cable (and of an unknown quality) I started having intermittent read / write faults. I had the drive replaced by the store the next day. I started having the exact same issue with the new drive as well. I was told by the store manager when I tried to return the second drive that I should use the supplied cable, and when I did - it worked flawlessly.
Make sure your power supply (if yours included one) is connected too. Hopefully, the will solve your problem - good luck!
Posted on Nov 08, 2010
How to transfer the data from the system to p.c
jamal_bshr,
There are many different ways to move your data from one system to another. It really comes down to what's cost-effective and what you have on hand.
The best way would to purchase an external hard drive (Western Digital's MyPassport series are my favorites due to reliability), then simply plug the drive into a USB port, move your files to the external hard drive, then copy the files from the external hard drive to your new/other computer.
Another option is to get some CD-R/RWs or DVD-R/RWs and burn your data to the CD/DVD, then move the data to your new/other computer.
Hope this helps.
-S
Oct 19, 2010 | HP Computers & Internet
My drive is not being recognised and im not sure why up in till this point it has worked fine? It is a WD Essential Model - Wdbaaf0010hbk - 1TB drive it has alot of valuble information that i would hate to...
when your external drive does not appear in "my computer" or not recognized in windows vista or windows 7, then just right click on my computer, click on manage, the go to disk management. Find your external drive there and right click on it, then select assign new drive letter. Select a letter from the midlle of the alphabet like m, then enter. The icon of your external drive should appear inside my computer
Oct 03, 2010 | Western Digital My Book Essential 1TB...
External drive not recognised by pc, do I need adriver update or is it more serious
Sep 27, 2010 | Western Digital My Book Essential 1TB...
My wd elements external hd is not recognized under windows 7. The pc diagnostics say that the device is working properly and the correct drivers are installed?
Go to Administrative Tools in Control Panel. Computer Management then Storage, Disk Management. You'll probably have to recognise it and assign a drive number.
Jun 18, 2010 | Western Digital Elements powered by WD 320...
WESTERN DIGITAL WBDAAR3200ABK-00 EXTERNAL HDD NOT WORKING
Every time windows tells you to format the drive, copy your data to your computer then format it. when windows detect problems on the drive, it will launch ckdsk, well i dont know hoy to fix it, try plugging it in then reboot.
May 02, 2010 | Western Digital Elements powered by WD 320...
Harddrive not being acknowledged by laptop
This is a hard one, as 7 is so new. But it sounds like the very next thing to do is to plug the drive into another computer to see if the drive is working properly. If it works well, make sure that your drive is not trying to grab a drive letter that is already being used by another device. Do a search on the MS website for known issues and instructions on how to check for drive letter management issues. Good luck.
Feb 26, 2010 | Western Digital My Passport Essential...
Laptop suddenly stopped recognising my external USB hard drive
I had the same exact problem with a WD2500xms passport. The problem was the USB cable. I went to the store and bought a 6' USB cable ( $26 at Radio Shack) with the same specs and now, no more problems. Also I called WD technical support (800.275.4932) and asked for a new cable. The WD customer serverice was very helpful and said it would sending me a new cable for free. When it arrives I'll return the 6'er.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Western Digital 250GB External Hard Drive not working
there are a couple of reasons for this. Likely the drive has not been setup in Windows. Hard drives need to setup in Disk Management. Disk Management can be found under Computer Management in the Control Panel. After you run Computer Management, expand the Storage tab and Disk Management is located there. At the bottom of the screen threre is a listing of all drives (hard and CD) located in or attached to system... You will see your new drive listed, but not active. Right click on the new drive in the bottom window and Windows will prompt you on how to configure the drive. You'll need to activate so Windows can assign a drive letter to the drive, partition and format. Once this is done, you will be able to see and use the drive under windows.
I've attached a link from Western Digital that provides their FAQ response to your issue.....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1017&p_created=1055796499&p_sid=7R8631pj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0yMjgsMTAxLDIxOSZwX2NhdHM9JnBfcHY9My4yMTkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXJlY29nbml6ZWQ*&p_li=&p_topview=1
You didn't mention what type of connection it uses (USB, etc). According to Western Digital, if you have a USB External Drive, you should get a prompt to install drivers by Windows when a new device is installed. Similar for Firewire device.... Did Windows "recognise" the new device by opening a New Device Found window? If not, try using a different USB port and/or ensure the USB port is enabled in WIndows.... The Quick Start guides for all models can also be found from the link provided above.
Jan 24, 2009 | Western Digital 250GB MyBook External USB...
Computers & Internet Logo
139 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
