Question about Apogee XHD Expansion Card for Pro Tools HD and ADDA16X Expansion Module
Hi,I was trying to configure my Rosetta 800 with X-HD card inside protools.Normally I work with a 192 digital,but the Hardware Setup only has recognize the rosetta the first times,actually protools don't see the rosetta in the Hardware setup,I have already installed the last firmware version,but can not get rosetta signal,can you help me please.Thank you and best regards
  • 3 more comments
  • Protools has seen the card the first time that I connected.but did not let me set it up, now turn on protools and is not detected the card, and thus can not see it
  • I've seen in several forums that this problem has happened to many users of X-HD card for Apogee, but no write forum solution.
  • Basically it is a communication problem of the rosetta 800 with protools, due to the X-HD cardhttp://duc.digidesign.com/showthread.php...
  • So if I have no solutions can send me my money back
  • please I know there are solutions to my configuration problems between the apogee X-HD card and the 192 digital in protools 8 because I write it,can somebody help me?
    Master:
  • 497 Answers
Hi, Try do the following:
1) Uninstall all Hardware & Software related to the issue.
2)
USING THIS MANUAL
In this manual, "parameters" are defined as the characteristics of operation, such as
CLOCK SOURCE or AES format, and are capitalized in this manner : CLOCK SOURCE.
"Values" are defined as the choices available for each parameter - for example, the parameter CLOCK SOURCE has the values INTernal,WC and INPUT Values are italicized in this manner: S/PDIF.
"Settings" are defined as the entire set of parameters and values.
When physical controls such as buttons or switches are referred to in the text,
they are highlighted in this manner: DOWN.
RESET
To reset the AD-16X, power up the unit while pressing the DOWN button. This provides a quick method to return to factory default settings when exploring the unit's functionality and capabilities. When reset, the conversion level is set so a +4 dBu analog input results in a -16 dBFs digital output.
QUICKSTART
Follow these simple steps to get started quickly:
1) Connect an AC input and the desired analog inputs and digital outputs to the AD-16X's rear panel.
2) Reset the AD-16X by powering up the unit while pressing the DOWN button.
3) Once the AD-16X has booted up, the CLOCK SOURCE will default to INTernal and the SAMPLE RATE will default to 44.1kHz.
4) If lock to an external word clock is desired, press the DOWN button until the WC lights .
5) To change to another sample rate (if CLOCK SOURCE is set to INTernal), press the NEXT button until the Sample Rate Display flashes, then press either the UP or DOWN buttons to select the desired sample rate.
6) In the clock window, verify that the desired sample rate is indicated and the"Lock Exclamation Point" is lit. If an X-Option card is installed, the AD-16X may be set in an Advanced Option routing configuration; please see page 9 for details.
3) Click on this link to Download the User Manual and Go To Page 9.
http://support.apogeedigital.com/assets/documentation/ad16x_usersguide.pdf
4) Click on this link to Download/Install All the CURRENT UPDATES for EACH SOFTWARE PROGRAM. Be sure to follow Installation Instructions.
http://www.apogeedigital.com/downloads.php
Posted on Nov 09, 2010
    President:
  • 2,777 Answers
So wait, Protools does see the Rosetta device, or it does not? It sounds like the computer at least saw the device if you updated the firmware, correct?
Please clarify a bit here... I read your question 4 times and still can't make heads or tails of it really... does protools see the rosetta but just can't read the signal, or it does not see it?
Thanks,
Tim
Posted on Nov 08, 2010
  • Tim Grayson
    Tim Grayson Nov 08, 2010
    Yes I am seeing that is a known issue with the hardware, unfortunately there is no workaround for it... They are working on a ProTools update to support it, but it will be some time for that.
    I am so sorry about that..
    Tim
  • Tim Grayson
    Yes you are eligible for a refund, just write in to the site at premium.support@fixya.com and they can get you refunded.
    Thanks
    Tim
My VGA has been corrupted. How can I fix it?
Hi , I suggest to check for any thermal issues including condition of the video card fan / heat sinks ie dust ,
If supported you can run a LINUX disk like Ubuntu in live / try mode
If video works ok , then most likely a Windows environment incl hardware conflict or virus / driver corruption issue ,
but if not then most likely a video card hardware issue like bad card cooling fan or excessive dust - thermal shedding issue or card bios/chipset fault
If a likely software issue then uninstall and then reinstall the video card
Consult ASUS or Nvidia support
The procedure is something like this
Onboard video support ?
yes
uninstall the video card driver and any video vendor configuration applets
Uninstall video card in device manager if still present.
Shut down and remove mains power cable
remove the hardware video card ,
(using anti static electricity procedures)
Attach onboard video to display
Power up and enter and configure BIOS setup if required, ie 1st seek onboard video
Bootup to Windows
Install the onboard video device
using Windows plug&play default driver executed during booting
Restart
Confirm working ok
Update the chipset driver (inf) if applicable,
restart
Shutdown
Reinstall the hardware video card
Attach to display
Reconfig BIOS setup if required
Start to install default driver
Install video driver / update from card default using a known good driver whose setup file has been previously downloaded
restart and test
Hope this helps
Dec 06, 2013 | ASUS GeForce Computers & Internet
Maudio 192 output
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
Sep 09, 2008 | M-Audio Audiophile 192 Sound Card
I have a Rosetta Stone V 3.4.5 and Win Xp. Rosetta Stone doesnt recognize the mic. What can I do to fix this error. The number of th error is 1117. My OS is Win Xp Waiting for help Alex
Create a security exception. 1. In ESET NOD32 (Smart Security 5), click Setup.
2. On the Setup screen, click Enter advanced setup... (bottom of screen).
3. On the Advanced setup screen, open Computer -> Antivirus and antispyware -> Exclusions.
4. Click Add , locate/select the Rosetta Stone Version 3 executable, then click OK. (In my case, the executable was in the C:\Program Files (x86)\Rosetta Stone Version 3 folder.)
5. Click OK on the Advanced setup screen.
Set the Rosetta Stone compatibility mode. 1. Right click the Rosetta Stone desktop icon or Start -> All programs -> Rosetta Stone.
2. Select Properties from the list.
3. Select the Compatibility tab.
4. Check the Run this program in compatibility mode box.
5. In the list below the check box, select the OS (in my case, Windows 7).
6. Click OK.
Sep 23, 2011 | Rosetta Stone Spanish (Latin American) -...
I fave a microphone in my web camera. And Rosetta Stone detects it. But I can't pass the microphone setup before a leson. I can speak for hours, but Rosetta Stone doesn't stop the checking. However it can...
I solved by going to Control Panel, Sound, Recording, then click on your mic and click on Configure, and then Set up microphone... Thats probably going to fix your problem... That easy... xD
Apr 04, 2010 | Rosetta Stone V3 English (U.K.) Level 3...
I have several 600's and they all have the same issue. They are giving 161 192 163 errors. I replaced the battery in them and then go to try and setup the time. However, instead of letting me set the...
161 = CMOS configuration lost (battery has died).
163 = CMOS error; Clock is not updating.
192 = System fan is faulty, not plugged into the system board or the system board itself is faulty.
Whe you replaced the RTC (real time clock/BIOS battery) did you make sure that the CPU fan was working?
If it is then go back into the BIOS and reset it to defaults. Save the changes and reboot, then go back into the BIOS and try to set the time and date.
Regards.
Feb 22, 2010 | IBM ThinkPad 600 Notebook
Hardware problem
hi, re- install your driver properly.. or download updated driver to work properly..
regards
Nov 12, 2009 | Computers & Internet
ProTools LE7 cannot locate hardware on startup.
There is something that I have learned about computers and it is now posted on a big sign over my desk "WHEN IN DOUBT, RE-BOOT" and that's what I did. It solved my problem.
Thanks for getting back anyway.
Nov 02, 2009 | Digidesign Mbox External Sound System
Setup
plz give solution how to driver install
May 31, 2008 | Digidesign Mbox External Sound System
9-16 channels issue
So you have your core card and how many accel cards?  Which interface is plugged into your core card? If you want the lynx to be 1-16 in and out the easiest thing to do is to make sure it is plugged in to the core card and your rosetta is plugged into the accel card installed after the core card.  As far as I know the power sequence won't change the assignment of the i/o.  If you don't want to change where the interfaces are plugged in then you can do it in the i/o setup and save the setup for the way your interfaces are plugged into the computer.  If your already plugged into the computer like I said then you will need to check the i/o setup to make sure the i/o setup isn't all scrambled.
Nov 19, 2007 | Lynx Aurora 8 and 16: Aurora 16 Sound Card
Apogee XHD Expansion Card for Pro Tools HD and ADDA16X Expansion Module Logo
277 people viewed this question
Top Apogee Computers & Internet Experts
David Payne
David Payne
Are you an Apogee Computer and Internet Expert? Answer questions, earn points and help others
