Question about Pioneer PRS-X720 Car Audio Amplifier
ON MY Pioneer PRS-X720 Car Audio Amplifier WHEN I TRY TO HOOK UP THE BRIDGE LITTLE SOUNDS COMES OUT THE SPEAKERS I HAVE TWO 12S MTX THUNDER IN THEY ARE IN A 2OHMS BOX BUT WHEN I HOOK UP JUST ONE CHANNEL IT SOUNDS GOOD I TRY BRIDGING IT BUT NO SOUNDS THE AMP DES NOT CLIPS OR ANYTHING JUST THE SOUND IS HORRIBLE DOES ANYONE HAS ANY SUGGESTION IS THERE POSSIBILITY THAT MY BRIDGE IS BURN OR MY 2 CHANNEL? PLEASE HELP
    New Friend:
    Problem Solver:
  • 15 Answers
Your amp can't handle 2 ohms bridged only 4 ohms bridged so just keep it on one channel and it should be fine
Posted on May 31, 2014
    Sniper:
  • 59 Answers
From the specs this amp can only handle 4ohms when bridged but can handle 2ohms when it's not bridged
Specifications
  • Continuous Power (20Hz-20kHz, 0.04% THD)
    • 2 ch: (4 Ohm) 100Wx2
    • 2 ch: (2 Ohm) 200Wx2
    • 1 ch: (4 Ohm) 400Wx1
  • Maximum Power (EIAJ)
    • 2 ch: (4 Ohm) 250Wx2
    • 1 ch: (4 Ohm) 750Wx1
  • Frequency Response: 10Hz - 50kHz (0,-1dB)
  • Total Harmonic Distortion: <0.01% (1kHz, 4 Ohm)
  • Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
  • Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Hope that helps.
Posted on Nov 08, 2010
What other MTX Thunder amplifier can i hook up with a MTX Thunder 6152 amplifier??
Not sure what you are trying to do, but you don't hook up one amplifier to another. You can pick any brand or model amp to drive other speakers than the ones that you are driving with the 6152. Just consider the power needed to push the speakers at the impedance they are rated(and hooked up)at. Look at the owners manual to determine if you need another amp. Hope that helps a little.
Apr 16, 2014 | Car Audio & Video
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
It seems my pioneer prs x720 won't ground out to my frame on my car, i have the power 12v wire connected striaght to the battery. Would it be the fuse on that wire? or would it be just because it's not...
the ground is the most important part of a car system. you should always ground directly to the frame and on a piece of bare clean metal...sand thepaint off if necessary. if not that check the fuse on the power wire if its a glass tube fuse it may have abad connection tht you cannot see under one of the end caps. go with a maxi or anl fuse!
Sep 14, 2010 | Pioneer PRS-X720 Car Audio Amplifier
Can i bridge this hifonics amp
If you don't know if the amp is bridgeable, then I wouldnt do it. It could already be bridged internally and bridgeing it through the speaker terminals could be disatrous, i.e. the infamous blue smoke of death. The amp looks like a 2 channel amp fromt he pic and you have two speakers you are trying to power with it. So the safest bet would be to just unbridge your speakers and hook them each up to the amp as normal. No blue smoke. Good luck!
Feb 18, 2010 | MTX Thunder 801D Car Audio Amplifier
Setting for...
HI DUDE .. U CAN ONLY SINGLE PC OF JL SUB BY BRIDGE MODE ... COZ UR MTX AMP HAVE 300WATTS RMS ....
Apr 05, 2009 | Alpine MRD-M301 Car Audio Amplifier
Mtx thunder 1501d
yes you can not run amps with your speakers being grounded un ground and then try
Nov 26, 2008 | MTX Thunder 1501D Car Audio Amplifier
Prsx720
The specs I read on the Pioneer site say the amp is not 1 ohm stable, so keep that in mind.
It partially depends on the impedance of each voice coil on the DVC subs. If they are dual 4 ohm, and you connect the DVCs in parallel ("+"s together, "-"s together), you could run a sub on each channel of the amp(s). This would put about 200W on each sub.
The other option is to still tie the dual 4 ohm voice coils in parallel, tie 2 subs in series (one "+" to the other "-"), and bridge the two channels of the amp (aka put them in parallel). But this, also, would be about 200W on each sub.
Things get different if the subs have dual 2 ohm, 3 ohm, or 8 ohm voice coils.
Mar 15, 2008 | Pioneer PRS-X720 Car Audio Amplifier
Pioneer prsx720 wiring question
If the subs are dual 4 ohm voice coils, you could hook the DVC's of each sub in parallel ("+"'s together, "-"'s together) making each sub essentially 2 ohms. Then connect one sub to each channel of the amps. This will put about 200W on each sub.
Mar 14, 2008 | Pioneer PRS-X720 Car Audio Amplifier
MTX Thunder 8302 Car Audio Amplifier
could be bad mosfets or outputs, needs replace
Aug 05, 2007 | MTX Thunder 8302 Car Audio Amplifier
Pioneer PRS-X720 Car Audio Amplifier Logo
167 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
