WHEN SWITCHED ON FAN CAME ON AND IGNITION FOR ABOUT 1`0 SECONDS THEN SHUT OFF AND E1 CAME ON. I AIR BLEW DUST FROM FILTER CLEANED ELECTRIC EYE WITH A CLOTH Q TIP AND BLEW IN FUEL LINE TO BE SURE IT WAS CLEAR. NOW ALL I GET UPON TURNING IT ON IS FAN AND FUEL VAPOR BUT NO IGNITION AND THE E1 LIGHT HELP TKS ED
    Guru:
  • 1,524 Answers
Make and Model number please. Gas or Oil.
Posted on Nov 08, 2010
Pressure washer will run for a little while the it just dies
under the carb, bowl is there an electric fuel shut off. sometimes they stick shut or hardly open so sounds like it is open enough to fill bowl with gas but not enough to keep it running
Nov 22, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Sears 417.80042990 keeps blowing thermal fuse
Did you clean out the lint filter at the front, heat is the enemy. Clean out all lint from front, if you are handy, get around back and remove all lint and dust by blowing compressed air.
Sep 21, 2012 | Frigidaire FEQ332E Electric Dryer
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
E1 shows and i unplug the unit and it will run for about 2mins and shut down with e1 showing
The E1 error code indicates that the air intake filter is dirty or clogged and needs to be removed and cleaned. Turn the unit OFF & unplug it, before removing the filter. Never operate the unit without the filter in place. Doing so, can damage the unit.
Hope this helped you & thanks for choosing FixYa.
Sep 20, 2011 | Haier Heating & Cooling
How to clean the dust out of the fan? its becoming very hot when in use.
Normally there is a dust filter on the fan and must be cleaned on occassions when you think that the PC is working hot. In some cases the PC will be shut off as the thermistor detects a higher temperature in the processor.
The fan unit can be removed and cleaned from the bottom side.Use good air pressure jet to clean.
Feb 04, 2011 | Compaq Presario Notebook
Vanguard twin 303447 drops a cylinder when hot under load have to have choke on to keep it going,have cleaned carby and tank plus checked compression and spark
there is hose coming from your valve cover to pump. check it for cracks. one of your gaskets at the air filter housing to carb or carb to black block or block to intake maybe leaking. fuel shut off solenoid could be going bad. choke cable adjustment. there is crank case breather under air filter housing with a s shaped hose coming from it to air filter housing make sure it is not loose. i have an engine at work that did =the same thing. i work at a golf course. i am the mechanic. i changed the hose from valve cover to pump and it cured that problem
Nov 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Motor runs erratically
Try cleaning the air filter and the fuel filter. Sawmills are dusty places and timber dust can clog-up air filters. Air filters in chainsaws are cleaned hourly for max efficiency.
Oct 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Flashing E1 -cleaned filter still have msg
clean the coil remove the filter and use a spray bottle with a little cleaner diluted bleach/water mix or a cleaner like widex and spray the coils from top to bottom dont wipe the coils will cause other problems just spray a few times to get the dirt/dust clogging the coils free than rinse with water not a lot use a spray bottle turn on fan and let run for a few than turn off and replace filter and try unit
Oct 01, 2009 | Danby DAC6003D Air Conditioner
AIR CONDITIONER MODEL #AF-S85FX--CODE E1 COMES ON-CLEANED FILTER, BUT UNIT WONT RESET AND KEEPS DEFAULTING BACK TO CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Jul 24, 2008 | Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
