This must be happen due to some fault in your dvdrom you must check your dvdrom by using it on some other pc and if that problem remains same then you must get it checked by any specialist . as it must be happen that its lens must be weak or totally dead /// last but not the least you must check the policy of your software setting their are some chances that some one had make policy of not using the dvd rom to check this you must type GPEDIT.MSC in your command prompt . i hope your problem will solve soon
Posted on Jun 16, 2008
The pc don't reconise the hdd
Test all leads that attach to your hard drive including electrical extensions,IDE
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps you
Jan 05, 2012 | Transcend 64GB IDE 2.5inch Solid State...
My cd drive does not reconise any cd/dvd, cant install new software. I have a Fujitsu Amilo laptop.
Does the drive show up at all under "My computer" (in Win XP) or "Computer" (in Win Vista or 7)? If not then try this "fix it" article from Microsoft. LINK
If the drive shows up, but it won't read any type of disc, then the most likely cause is that the laser has died in the drive, and the drive would need to be replaced. This is fairly rare in newer optical drives, but was rather common in drives produced more than 6 to 8 years ago.
Nov 14, 2009 | Fujitsu Computers & Internet
My desk top comp dosent reconise dvd rw drive
1/ first re install dvd softwere to check
2/ change data cable and power to check
3/ look on biob rom is shoing or not.
4 if not work change another new.
Nov 04, 2009 | Computers & Internet
DVD drive not working
check dvd drive if detected in bios
1. test any media dvd and cd, if fails
2. uninstall / reinstall firmware if fails
3. check if dvd drive icon is visible from my computer window, if not
4. donwload the fix here
5.replace dvd drive
Oct 08, 2009 | Dell Inspiron 1545 Notebook
He dont reconize his cd-dvd drive
Please check device manager first, Right click on my computer which you will find from either your destop or from start menu.
Select manage, on the management window, on the left side click on device manager.
Now on device manager, on the right side, look for your CD/DVD drive, do you see any ? yellow marks there?
If you do see right click on the spesific device and select properties, then write down the status message to me.
Aug 14, 2009 | Acer Aspire 5100 Notebook
My computer wont reconise it
go to bios settings then set the DVD as a SATA or IDE drive and check easy the IDE or SATA connector from the back of DVD player to Mother Board connectors...
May 23, 2009 | LG Computers & Internet
Will Not reconise Cd or DVD in the Drive
Yes, this drive is basically dead. You can find pretty cheap prices for new drives at
If the drive door closes on a cd or dvd that you want and it will not open back up, use a straightened paperclip and push it into the little hole near the door on the drive, the door will pop open then.
Mar 29, 2009 | Sony DW-G120A DVD RW Dual Layer Burner
Can't reconise my dvdrw rom drive
check in bios settings your dvd is found or not reset your bios load optimal defaults.
Mar 10, 2009 | Acer Aspire 5610 Notebook
try to set BIOS as auto detect
turned off computer & unpluged main power lead
unpluged IDE CD/DVD-ROM if any
Jun 12, 2008 | Pioneer DVR-107D DVD±RW Burner
My pioner dvd dr 1120 d wont reconise blank dvd's
Open it with NERO softwer and add some files to burn, down at the right end of window (nero's) have a line that says how much space on disc there is.
Simple as this, I just caimed from my DVD dealer and he explained to me, Empty disc will always say 0 Bytes but if you open Nero Burner you'll be able to se how much of space is free on scale, after and whille adding files to burn image.
Hope you understand me :)
Sep 29, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
Computers & Internet Logo
David Payne
David Payne
