Question about Coby DVD-937 5.1 Channel DVD Player/Receiver Home Theater Speaker System System
Disc loader stuck in in position. Can I get it to release?
    Guru:
  • 2,178 Answers
Check for a small hole on the front of the drive. Insert a straightened paper clip into the hold and push sharply. The door should slightly pop out - pull it open.
Posted on Nov 08, 2010
Dvd stuck in home 7-cd/dvd changer
So you want to remove the disc without damaging the disc? so its ok to damage the player.
Put a cushion on the floor, put player on it.
Use a strong pair of pliers to crush and bend all the plastic parts of the loader near the disc, shake the player so that the disc falls onto the cushion.
Dec 21, 2013 | JVC Audio Players & Recorders
Philips DVD recorder, (250gb) DVDR3460H. can not remove disk .........
your gonna have to open the machine up the there is a whits tab that lifts the disc up to spin you will have to use your fingers to slde it of that make sure its unplugged and then the white thing will realese
Sep 19, 2008 | Televison & Video
How can you release cd's stuck in cd changer system?
It depends on the type of loading mechanism is used, for example! if unit is a 5 disc changer, remove top and advance platter to remove disc's. If the CD player is a slot loader remove top and see if disc's can be teased to come out a more difficult removal, finally if this is a mega loader get someone who knows what they are doing and remove them safely.
Mar 18, 2012 | Audio Players & Recorders
I HAVE A 6 DISC CHANGER IN MY 2006 NISSAN MAXIMA. ALL OF MY CDS ARE STUCK IN THE CHANGER AND WON'T COME OUT. DO YOU HAVE ANY SUGGESTIONS?
it is the problem of cd changer.the mechanism that takes the cd from the loader to the changer is stuck in between.it has to be at a predefined position and it is not there so the changer has stop the operation.only quatified service man can repair it.
Aug 18, 2010 | Audio Players & Recorders
Can you manually release a DVD from the Panasonic S32? The DVD player 'died' - with a CD inside. The instructions are silent on a manual solution.
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!!
Apr 01, 2010 | Panasonic Televison & Video
CD/DVD drawer won't open so CD stuck inside :(
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
Dvd is stuck
Before you remove the DVD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
  • Use the opportunity while you have the outer casing off to clean the lens of your DVD player.
  • Never work on an electrical device that's still plugged in.
  • Opening a DVD player may negate the warranty. Read yours carefully before you proceed.
  • Follow these steps to remove it
    Step 1 Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Step 2 Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
  • Step 3 Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
  • Step 4 Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet.
  • Step 5 Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
  • Step 6 Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
  • Oct 10, 2009 | iLO DVDR05 DVD Recorder
    Disc Loader got jammed.
    Remove the top cover.  You will see where the disc are, take care in removing the stabilizer housing, you should be able to get the dvds out and put it back together.
    Jan 04, 2009 | Philips DVP642 DVD Player
    DVD Player won't open
    Try this. This works on some brands and models.
    Power up the unit. Using the remote, press and hold the 'STOP' button for about 5 seconds. Release and press the 'OK' button.
    Jun 18, 2008 | Samsung DVD-V4600 DVD Player/VCR
    87 people viewed this question
    Top Coby Audio Players & Recorders Experts
    Gyula Lacz
    Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
