Question about Yard Man YardMan 173 cc OHV 19" 3in1 Rear Wheel Drive Mower with Electric Start ()
I have a yardman 173cc vacume chipper schredder the engine won't start. has a pull cord when i shoot ether into carberator it's starts right up otherwise will not start.
  • 718 Answers
If you store this machine outdoors than you might have a little water in the system, otherwise give the carb a good cleaning.
Posted on Nov 09, 2010
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Yardman wood chipper stalls every 10 minutes
What brand engine do you have? B&S? I would start with the fuel system first. Make sure fuel filter is not clogging, check and make sure that the vent cap on the gas tank is not clogged. If the cap is clogged, it creates vacuum in the gas tank which will eventually prevent proper fuel flow going to the carburetor. If your engine has a fuel cut off solenoid (Located Under Carburetor) check the wire connection going to it and make sure that all connections are good in that circuit. You should see battery voltage going to the solenoid when the ignition is turned into the run position. The electric solenoid that opens and closes the plunger that allows fuel to flow into the carburetor could be failing when it gets hot. These fuel cut off solenoids don't commonly electrically fail but the plunger can start to stick causing lack of fuel flow or no fuel flow. They are normally in the closed position when ignition is turned off. Hopefully this information will help you out given the fact that I'm guesstimating on the engine that you may have. Take Care.
May 19, 2013 | Garden
Pullcord wont pull out to srart engin
ok. 1. you are not pulling hard enough,or the turning of the motor is jammed or seized. look under mower deck for an object jammed w/the blade and deck.
Apr 24, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
93 S-10 blazer, vortec v 6 cpi, when cold it is very hard to start, you have to shoot ether and it will start right up, new fuel pump and filter and fuel pump relay, once it starts it will start right back...
Issue with PCs Valve Check for vacum lost cracking rubber connection Pre-Heater and Primer System Mal-Functional Check also for Idle sensor Relay for bad connection....good luck
Sep 28, 2010 | 1993 Chevrolet S-10 Blazer
I have a troy built chipper schredder vac built by garden way in 1992 that has a tecumseh engine model h50-65578t that i would like the carb adjustments .
start at one and a half turns each ,run at full throttle turn outhigh speed screw (bottom) until it starts running flat, turn back untill runs clean. same procedure for low speed screw but at idle speed .when done turn throttle to high speed if boggs open low speed screw alittle bit at a time untill accelerates with out bogging hope this helps
Aug 09, 2010 | Troy Bilt Builtchipper...
Need owners manual for 2001 yard machine chipper schredder model #24A464B131
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. (wchan@bushbros.com)
Mar 27, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
MTD yardman chipper wont start get spark need manual
I am successful too at using the starting fluid in the carb or directly into the clinder. That is how I start my MTD 5.5hp chipper. My problem is I have to hold down the primer bulb to keep it running. If not, the engine will stall.
May 12, 2009 | Troy Bilt Walk Behind...
5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Mar 30, 2009 | Heavy Machinery
Yard Man YardMan 173 cc OHV 19" 3in1 Rear Wheel Drive Mower with Electric Start () Logo
287 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
