How do you install the correction tape on a Swintec.2410?
3 Suggested Answers
  • 3594 Answers
SOURCE: Changing correction tape on swintec 2600
Be sure the corr. tape not a tacky kind, then type some thing and correct it watching the mechinism th see which one turns and in what direction. Install the empty spool on that hub thread the L/O thru the guides with dull side facing the paper and then the full on the supply hub. there may be two or more guides depending on the printer.
Hope this helps
DickyO
Posted on May 05, 2008
  • 3594 Answers
SOURCE: The caps lock on my
I don't know if tou are talking about shift lock ir caps mode. If it is shift lock gently pry the S.L. keytop off, push down thu the small hold in the middle of the stem if that makes it work make small spitball and push it down the hole, replace the key top. if this dosen't work you need a new contact pad in the keyboard.
DickyO
Posted on Nov 11, 2010
How to replace correction tape?
From the looks the typewriter is not electric but electrononic. Wind it the same way the old lift off tape was guided. The full spool on the left hand side around the guides in the front of the printwheel to the right side with the empty spool. Simple.
Feb 12, 2016 | Swintec 2600 Electric Typewriter
CORRECTION RIBBON
The correction ribbon is installed on a separate mechanism on a typewriter. If you look between the regular ribbon guide and the card holder you should see the correction ribbon guides on the right and left hand side of the card holder. the spool holders will be to the right and left of the correct ribbon guides. This is true only if the typewriter has a correction mechanism installed. Some machines do not have a correction mechanism. Correction is achieved by using a correction tab which is held by hand, in front of the letter to be removed, or white out. Some correction tapes attach to the bottom of the print ribbon.
Nov 06, 2013 | Swintec Office Equipment & Supplies
Where can I look at a manual for a Swintex 2410 typewriter?
I needed the manual for the Swintec 2410, TOO! I found an add on eBay that happen to show a photo of the metal MODEL label on the typewriter. It listed an additional Model number that led me to the: Nakajima Typewriter AX 150. Seems to be the same machine / model of typewriter with manual online! Manual for that at: http://www.nadist.com/WPT150_Operation_Manual.pdf
Jul 14, 2011 | Cameras
As soon as I turn our Swintec 2640 on it starts beeping very rapidly.
Be sure the printwheel doesn't have any bent or broken spakes. Try it without the bribbon and correction tape to see if they are hitting the P/W.
DicyO
Feb 15, 2011 | Swintec 7040 Typewriter
For a Swintec 8014 typewriter: the bottom portion of the letters are not tranferring to the paper when the keys are striked. although the ribbon shows the full letter being striked, only the top portion...
Check to be sure the ribbon dosen't have a fold in it and is fully seated in place, be sure the platen is fully seated in the side frames, check the correction tape for proper imstallation it can rob the print if to high.
DickyO
Dec 03, 2010 | Swintec Office Equipment & Supplies
The caps lock on my Swintec 2410 typewriter suddenly won't lock anymore. Suggestions?
DickyO
Nov 09, 2010 | Swintec Office Equipment & Supplies
Hope this helps
DickyO
Apr 28, 2008 | Office Equipment & Supplies
125 people viewed this question
k24674
jasbo
jasbo
