Question about Samsung PN50C550 50 in. TV
Does samsung hdtv series 5000 support arc ? - Samsung PN50C550 50 in. TV
Need a copy of schematic for Samsung TV UN39FH5000f
http://www.servicemanuals.net/SAMSUNG/UN39FH5000-NO-SCHEMES/1581155/detail.aspx
Dec 06, 2016 | Samsung 5000 Series UN39FH5000 39" LED TV...
When selecting the source, HDMI 2 will not highlight, Only TV. HDMI cable connected to box and to HDMI2 port on TV
You have to check the HDMI cable. In Samsung tvs the HDMI sources only highlights if the a proper HDMI sources is connected to the corresponding HDMI port of the tv. Also check by connecting any other device which have and HDMI connectivity to the HDMI 2 port.
www.electro-medical.blogspot.com
https://www.facebook.com/electromedservices?fref=nf
Oct 02, 2015 | Samsung UN22F5000AF 22 LED 5000 Series TV...
Why wont my tv wont turn on
The power supply may have blown capacitors. Check to see if it is still covered by the warranty and check to see if it was affected by a Samsung recall. If not, then unless you can replace capacitors inside the TV itself, it is time to take it to a service center.
Dec 01, 2014 | Samsung UN22F5000AF 22 LED 5000 Series TV...
Samsung remote does not change chanel
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
Jul 22, 2014 | Samsung 5000 Series UN39FH5000 39" LED TV...
I want to buy a power arc 5000 but i want to know about **** durability
The Power arc 5000 gen. is really durable. I have had mine now for 5 years and have had no problems with it I use it for all my power tools on job sites.
Mar 01, 2010 | Lincoln Electric POWER ARC 5500 HONDA
Samsung DLP HL-R5667W lamp won't fire. Changed lamp & ballast and still won't work. Fans are working fine, color wheel good. Lamp door switch good. When I power on, I hear ballast buzz like it's trying...
Was the replacement lamp the same part number as the original as there are different arc gaps for different lamps and the wrong arc gap will cause the lamp not to light. Since the ballast is powering up the lamp should light if the baalast is matched to the correct arc gap of the lamp being used.
Nov 27, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung PN50C550 50 in. TV Logo
466 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
