Question about Onkyo Audio Players & Recorders
I cannot open the right tape deck door. - Onkyo Audio Players & Recorders
    Guru:
  • 2,178 Answers
The mechanical section in the drive need overhaul - belts, idlers, and all rubber parts are either slipping or broken. Take it apart and check the belts.
Posted on Nov 08, 2010
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
MHC1500 Sony tape player is stuck! got deck door open, but tape will not eject. does not appear to be any loose tape. How can I get the tape cassette outf?
Prying the door open is not the first thing that should have been done. The mechanism for the tape transport is having a problem in that it either need service or the belt is too loose. A Technician would open the deck get the mechanism in the stop mode and then eject the tape. Any other way just damages the unit and might make it unrepairable.
Feb 14, 2013 | Audio Players & Recorders
Doors will not open
Probably need a new transport mechanism belt. In any case open the deck up and see if the belt is loose. Then turn the pully with finger until tape is released. Do not force- if high resistance is had then turn the other way. You will need to get a belt if you see a loose one. It could also be a bad motor for that function. I am not looking at the SM right now.
Dec 29, 2012 | Technics RS-TR575 Single Dual Cassette...
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
Sony mhc-2600 tape stuck
The tape has spewed out in the mechanical section preventing the door from opening, some outer doors can be removed by too thumb screws sliding up and out, others are held in by plastic clips, the door may have to be pried open to get the outer door off to remove the tape.
Jul 27, 2012 | Sony Audio Players & Recorders
I have a Sherwood DS1150 tape Deck. Problem Cant open Cassette Door, tape is inside . Will not rewind or fast forward. Wont play. Any advise
Very likely the tape is wound around the capstan.
You may have to get at it by taking the unit's case off.
If I am right you might have to destroy the cassette unless you are very careful. Or, at least, have to cut the tape so as to unwind it from the capstan.
You could also try to open the door just enough to lift it up and off ... as if you were going to clean the tape heads.
Mar 12, 2012 | Audio Players & Recorders
SONY TC-WR550z dual tape deck eats tape and doors won't open I hadn't used this unit in 5 year (it's 13 or 14 years old), and before it worked fine. I went to use it again last month (MJ "Thriller" tape!)...
I don't know anything about the "eats tapes". You can take out your tape fairly easily thought. All you need to do is
unscrew screws on the left and right side of unit
remove the cover
use a flat head screw driver to gently push down on a white lever on the side of the drive mechanism while pushing the eject button
Sep 13, 2009 | Sony TC-WR565RM Single Cassette Deck
Marantz Cassette Deck Model Sd 35 Tape door will not open
It sounds like the drive belts on the deck have broken (not allowing playing, FF or REW) and/or the tape got "eaten" meaning the tape itself has wound itself around the rollers and cannot free itself. I strongly doubt this is an electrical issue. Definately sounds mechanical.
As far as the door not opening, there's usually a hook that holds the door closed. If the unit is mostly disassembled, look near one of the sides of the door for a metal hook. It's normally spring loaded and can be moved manually. That should free the door. If your tape was eaten, it might take some gentle persuasion to unwrap it from the rollers.
Good luck.
Feb 04, 2008 | Audio Players & Recorders
Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
Dec 25, 2007 | Audio Players & Recorders
112 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
