Question about Garden
Got a stihl chainsaw want start. has fire to the plug, but seems to be getting to gas. everytime i go to pull start. than take the plug out it has alot of gas on plug.
    Brigadier General:
  • 4,088 Answers
Check the air cleaner and muffler for plugging. Is the spark at the plug blue and snappy? If weak looking, try a fresh plug gapped to 0.020". No help, check the ignition module gap--turn the flywheel magnets under the module poles (after removing the left side cover), insert a thin business card into the gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws, then turn the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the pole gaps don't close up at any point. Try for spark again, if better, try for start. If still flooding, you may need to service the carburetor--make sure the lower diaphragm is flexible and not cracked or punctured. Don't use the choke for more than one pull. Make sure to use fresh fuel mix and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Posted on Nov 09, 2010
Stihl MS 170 chainsaw will not start
remove the plug, hold the throttle wide open and pull about 10 times
replace the plug and hold the throttle wide open, pull to start
the stihl floods very easy and will not start until the excess in the crankcase is removed
Jan 19, 2017 | Cars & Trucks
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
Why does my stihl chainsaw spray gas out muffler and carburator
I had something similar a long time ago with my Stihl chainsaw. I removed the small carbeurator and found that the gas/ carb float was at times sticking in the open position allowing too much gas to flow into the piston cylinder. The spark and compression can theoretically burn so much fuel on each compression stroke of the piston and the residual ie; overflow of gas/oil mixture is forced out the muffler on the exhaust stroke. Keep in mind the engine is a two cycle stroke engine meaning it fires each time the piston compresses and therefore if it is the float sticking open it will seem like a great deal of raw fuel being forced out the muffler. I hope this will give you a starting point to look at. Good luck and hope you don't get discouraged because the Stihl product, especially the chainsaw is one of the finest produced and on the market today.
Aug 02, 2014 | Stihl Garden
Chainsaw troubleshooting
Sounds like the engine decompressor is stuck shut remove it clean up with carb cleaner and try again.
Jul 04, 2014 | Stihl 009l
Why is my Stihl HS61 not firing up?
Try cleaning out the carburettor and make sure u are using new fuel and the correct mixture
Jun 28, 2014 | Stihl Trimmer Blower Hedge Pruner...
Working on a Stihl 16" 031AV Chainsaw and have
Plug may have weak spark, as odd as it sounds it does happen, try fresh plug.
Sep 02, 2011 | Garden
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Won't start
I have the same model chainsaw, and sometimes it's very difficult to start. If you pull the plug and it's wet, with the plug still out pull the starter rope about ten times to clear out the excess gas. Dry the plug and put it back in and try to start it with the choke off. If it fires up, be ready to put the choke on if it starts. I forgot to mention that before starting you should pull in the trigger, push down the button on top of the handle, and hold it down while releasing the trigger. This sets the trigger so that it is on slightly. If it doesn't start, pull in the trigger and give it a few pulls that way. If it doesn't start, pull the plug again and see if it is wet. If it's dry, put the choke on and try to start it. If it still doesn't start, pull the plug, pour a few drops of gas in through the plug hole, replace the plug and try to start it with the choke on. If it still won't start, get a Stihl chainsaw.
Jul 15, 2009 | Garden
I have a stihl chainsaw that won't fire
DID YOU REMOVE THE PLUG AND CHECK THE SPARK AT THE GAP? IF YOU HAVE FIRE THERE THEN THE PROBLEM MUST BE A FUEL PROBLEM. ARE YOU USING A FRESH GAS MIXTURE? YOU CAN PUT A FEW DROPS OF MIXED GAS IN CYLINDER THEN RE-INSTALL PLUG TO SEE IF IT FIRES, IF IT DOES THEN YOUR NOT GETTING GAS FROM THE CARB.POSSIBLE STUCK DIAPHRAGM. GOOD LUCK!!!
Jan 24, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
