Question about Samsung CLP 300 Laser Printer
I have just replaced cartridges and am now getting fuser low heat error.
None of the cartridge lights have turned to red, but status light is red and "low fuser heat error" occurs.
Is this a problem associated with the fuser unit, I cant find this as a consumable anywhere printer is just out of warranty.
  • Anonymous Jan 14, 2009
    exactly the same problem - has anyone any idea how it can be fixed?
I have a clx-216N (same as a CLP-300N which I also have, but with a scanner). The Clx-216N has a display that gives you more informaiton than just lights.
Anyway same thing - replace a toner cartridge and soon after got this probem.
I noted first the fuser overheats (there was some smoke) and I think it burns something out in the fuser. Then it wont heat and you get a low heat error as the fusrer is now broken.
I replaced the fuser and then it gave an overheat problem soon after warming up so I turned it off quickly.
So it is something wrong with the electronics inside the unit. Replacing the fuser will just ruin another fuser. I think it is probably the thermostat - and since it happens after changing toner cartrideges maybe it is getting covered in toner somehow - just guessing.
Anyway I will send it to Samsung and let you know what happens and if it is worth fixing.Hopefully they give free quotes.
Posted on Oct 23, 2010
    Master:
  • 788 Answers
Yes, either the lamp in the fuser is burnt, the thermistor (heat sensor) on the fuser is burnt, or the low voltage power supply is not providing enough voltage to the fuser lamp. Your safest bet is to replace the fuser.
BUT!!!! The printer itself is let than $150 new with warranty, so if you like this printer I would buy a new one. A fuser will be between $90 and $150 and could be difficult to replace. If you get a service person to replace it you could expect two hours of labour at least which will be about the price of a new printer.
Posted on Jun 16, 2008
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
Toner light comes on and status light is red after replacing toner cartridge.
Oct 12, 2010 | Brother HL 5250DN Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
Status light goes green when power on, but then turns red and cannot print - replaced toner cartridge- not sure what the reason for the red error light is?
You have to reset your printer with a module or replace chip when you refill toner cartridges.
www.nakshatraworld.com
Jan 07, 2010 | Samsung CLP 300 Laser Printer
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
It doesnt print anything. the status light is red. i dont know whats wrong
A red Status light means 'paper jam'. A red light corresponding to one or more of the toner cartridges means empty cartridge. A flashing red light corresponding to one or more toner cartridges means low toner.
Aug 27, 2009 | Samsung CLP 300 Laser Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
HP DESKJET 1180C
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light Introduction The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed. Instructions The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
  1. With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
    1. If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
    2. If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
    3. If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
    4. If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
    5. After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2. NOTE: The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
    Figure 1: Cartridge status icons c00001225.jpg Icon/Drawing Problem identified by the symbol Solution c00001226.jpg The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed. 1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
    2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
    3. Check to make sure the color cartridge is appropriate for the printer.
    4. If the problem persists, replace the color cartridge. c00001227.jpg The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective. 1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
    2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
    3. Check to make sure the black cartridge is appropriate for the printer.
    4. If the problem persists, replace the black cartridge. c00001228.jpg The color print cartridge is running low on ink. Replace the color print cartridge with a new color print cartridge. c00001229.jpg The black print cartridge is running low on ink. Replace the black print cartridge with a new black print cartridge. c00001230.jpg None. The print cartridges are working correctly. None. The print cartridges are working correctly.
  2. Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
    1. Open the Access Cover and hold it open.
    2. Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
  3. Install the Access Cover by following the steps below:
    1. Align the hinges on the Access Cover with the hinge pins on the printer.
    2. Push down firmly on the Access Cover until the hinges snap into position.
  4. Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2. Figure 2: Pressure points c00006497.jpg Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5. Figure 3: Squeezing the pressure points c00006498.jpg
  5. If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
    1. If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
    2. If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
Oct 18, 2007 | Office Equipment & Supplies
Samsung CLP 300 Laser Printer Logo
718 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
