Home | Coffee and Espresso Makers | Revere Ware old fas...
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Revere Ware old fashioned coffee pot
By attack-cat on Jun 16, 2008
The coffee pot has Patent 2272609 and the number 2363978 on the bottom. It has a small bottom part (like a pot) with a small pouring spout, then a middle piece fits in that about the same size with a funnel design on the bottom and little holes in the bottom, a flat metal thing with a flat metal stick in the center fits inside the middle part and it also has holes in it. and last is the lid. No glass perculator thing on it just a black knob.
Does anyone know how to make coffee in this thing? If you could put some detailed instrcutions I would be very grateful! Thank you!
Comments:
Jun 20, 2008
- Thank you Charlie!
Best Solution
posted on Jun 18, 2008
Very Helpful)
kid_cleo
Rank: Apprentice
Rating: 95%, 3 votes
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
Hi, received a Russell Hobbs coffee maker Abbey Lane model RHG601 as a wedding present, with out... (More)
Answer
i have the Gaggia Syncrony digital , and it keep saying "fill Watertank"but its full, and... (More)
Answer
no water from hot water dispenser and no steam from steamer only produces the coffee
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
