Question about EliteGroup 848P-A V2.0 Motherboard
My screen keeps repeating the the "USB DEVICE NOT
Drive not recognized device
  1. Click Start, then type device manager in the Search box, then click Device Manager.
  2. Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Nov 20, 2013 | PQI 8GB PQi U273 USB 2.0 Drive Metallic...
When I Connect My Aiptek 8100 camera to the PC, they show a message "USB device not recognized." Is this because I did not install it's driver? If so please tell me where I can find the driver?
Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
Oct 03, 2012 | PC Mall 8100 (MODEL 8100) PC Notebook
I do not have an option to boot from USB
Two suggestions:
1. Try F10 or F12 during boot. There might be a boot menu without going into BIOS. Mine is F10.
2. Update CMOS / BIOS.
Aug 31, 2012 | AMD Processor, Phenom X4 9650 2.3GHz, 4MB...
Diamond vc500 "usb device not recognized" i have a
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Oct 21, 2011 | Diamond Multimedia ( VC500) Video Capture
Winxp sp3 andwin7 cannot recognized its USB adapter saying that it is an unknown device, i've tried to remove it from device manager and reboot, i also tried to update the driver through windows update...
The easiest way to figure out what is going on is to try the adapter on a different computer. If it is still good it will be detected. Usually when a usb device fails it may be recognized or is recognized only as a usb device but it will not work. You don;t have to install any drivers just to test this on another computer unless you want to make sure it is fully functional. It is also possible that the usb ports on the computer are not working or one isn't. Simpley use on of the other ports.The usb port controller usually operate a pair of usb ports so try all the ports. You may get a problem with one port or pair but rarely all at the same time.
I think you will find that the adapter itself is your problem and will probably need to be replaced.
Sep 15, 2011 | EnGenius EUB-9701EXT2 Pre-802.11n Wireless...
Not working USB data travelter 4 GB message error is USB device not recognized plz solved this problem and send me best clarification.
Hello and Welcome to FixYa!
The error you quoted can be due to multiple reasons. Following are some main Possibilities, that you should keep in mind.
Make sure, the USB port, you are inserting data traveler in, is in working condition. And you are connecting the device properly.
This could happen due to Software conflict, for this you need to remove all the devices connected to USB ports (other than keyboard, and Mouse) and need to restart the system.. Moreover, you can check for the exact error, in the device manager list...
Try checking the data traveler, on some USB port, on which you are sure, that its working properly.
Check for the possibilities, quoted above and do let me know....
Concerned.
Jun 25, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Device not Recognized in Xp+Sp3
you are better off getting a refund and buying a PCI wireless card and installing that instead ( linksys or netgear or something along those lines )
May 09, 2009 | Adapters.com USB Wireless Mini LAN Adapter...
EliteGroup 848P-A V2.0 Motherboard Logo
27 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Computer Links
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
