Question about GPS
The screen goes blank every 5 to 10 seconds and the image only reappears if I tap the screen.
  • 12,061 Answers
Hi sounds like you have either a bad connection on the battery, a semi-broken wire/connector or perhaps even a dry joint on the PCB. If it is in a certain place, make sure to include that info when you send in for repair. If you don't care about warranty etc, then there is no reason why you couldn't open the unit up, and check it out, looking for the problem, resoldering any suspect looking joints, and making sure all connections are OK.
Also check to make sure that it isn't a "Setting" like a screen saver? Have a look in the manual.
If it does indeed prove to be a faulty within the unit, the best thing to do is contact the manufacturer and arrange for it to be serviced, the manufacturer is the best place to get this attended to. Always ask for a "Quote" before allowing any work to be done.
Posted on Nov 08, 2010
Screen goes blank
I wonder which connector you are refering to. Sounds like a GPU issue to me.
Nov 27, 2013 | Acer Aspire 5500 5570-2609 Laptop
No image and audio for a few seconds
Your TV has symptoms of power supply trouble.
Nov 21, 2013 | Sony KDF-E55A20 55 in. LCD Television
Benq fp581 screen goes blank after about half a second evertime i turn on my computer.
Even thought the monitor looks blank check to see if you can see a faint image (shining a flashlight at the monitor sometimes helps). If you can see an image it could mean that the inverter board has gone bad.
I have also heard of an overheated computer causing a similar problem.
May 20, 2010 | Computers & Internet
Tom tom is dimming and blanking the screen within about 30 seconds. I can touch the screen and it reappears but does it again
Tap on: the main screen. Tap on: Change Preference. Tap on: Arrow Keep tapping on the arrow till you reach Preferences 6 of 6 Page. Here you will find Battery saving preference. Tap on it. Tap on: Never dim screen. (I think you selection would be dim screen between instructions at present.). Tap done. On the next screen select : Device stays on when external power is lost. (A green tick mark should appear to verify it is selected.) Tap done.
May 09, 2010 | GPS
Nikon D80 - LCD screen goes blank in the mountains
In the mountains, are you subjecting the camera to wide swings of temperature or humidity? These could cause your symptoms.
Sep 04, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
I have a Hyundai Image Quest L70S, the screen goes blank
hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Jan 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
Screen goes blank after 2 seconds!
Blank Blank or can you see shadows?
If you see shadow images then the backlight or inverter has failed
If it is blank blank then graphics card or connector/cable problem
Does that help
Dec 30, 2007 | HP Pavilion F1703 17" LCD Monitor
GPS Logo
27 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
