Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Set will not turn on and red light blinks four times
  • 95 Answers
4 blinks means that you have a problem on vertical section. It may be caused by defective vertical ic or open fusible resistors. Also check for loose or poor solder connections at vertical section. Check if there is a +&-- supply for vertical VCC..
Posted on Nov 09, 2010
Sony Bravia showing 4 red blinks any idea what this means, fault?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 27, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
On/Standby light flashes red four times
Dec 27, 2012 | Sony VPL-EX100 3LCD Projector VPLEX100
Blinking lights on HP MD6580n
Sounds like the power supply is overheating.
Oct 05, 2012 | HP Md6580n 65 in. HDTV
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Aug 12, 2010 | Televison & Video
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
E50a10 blinks four times
Four blinks is a fan rotation error code which means one of the four fans is not operating properly. Check these fans and replace any found defective.
  • Remove the lamp cover.
  • Remove the rear cover by removing the 13 screws holding it in place.
  • Check the fans.
053bd7d.jpgLocation of fans 1 and 2
Location of fans 3 and 4
Dec 07, 2009 | Televison & Video
My SXRD 60" Sony LCD TV turns on. green light flashes about 6 times, then solid green. But just as screen starts to light up, turns off, solid green light turns red and blinks red four times, then stops. a...
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
Oct 10, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Blinking red lights
I will need to know the model number of your set in order to be able to help you out with the problem, as different models have different error codes.
May 23, 2008 | Televison & Video
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
168 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
