Question about Watches
I have a fmdco053 watch in 24 hour time mode. how do i change it to 12 hour mode? thanks
I have this same model, it's 4 buttons with MODE on bottom left and light on top left. I tried all below doesn't work, but I figured it out. First you have to get it to blink where you would change the hours. The next part is tricky, I can't remember exactly how, but it's either you press the light button together with the top right button, or just repeat pressing the top right button until it cycle to the AM/PM.
Posted on Sep 06, 2013
  • 29 Answers
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Posted on Mar 12, 2008
SOURCE: how to set time Casio W-89H two button watch
Actually, the watch has 3 buttons -- "Light" being the 3rd one. Press Mode until a number in the time mode begins flashing. Then press the Light button to get it to the hour indicator. Use the 12-24 Hr button to set it to the current hour. Then press the Light button again to get it to the minutes section. Again, use the 12-24 Hr. Button to set it to the next minute coming up in the current time. Then push the Light button again. This will bring up the seconds indicator. At the precise time the minute you set before begins, hit the 12-24 Hr. button, and the indicator goes back to zero and begins ticing away. Then hit the Mode button again until the watch is in the current time mode. Hope this helps. I use Internet time to set a precise time.
Posted on Sep 21, 2009
cmcduncand
  • 714 Answers
SOURCE: how to change from 24 hour to 12 hour on g shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 19, 2010
SOURCE: How do I change my Casio twin sensor alti thermo
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
Posted on Feb 21, 2010
SOURCE: cannot change from 24 hour to 12 hour
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Posted on Mar 14, 2010
How do I get the watch out of 24 Hour (military time) display mode.
You will need to press the adjust button the same way you change the time and then by clicking the mode button you will get to an option to switch from 24-hour to 12-hour watch.
Mar 09, 2011 | Watches
Timex 1440 sport indiglo 50m convert from 24 hour clock to 12 hour clock.
There are several models of your watch not all of which appear to have a 12/24 hour display format.
Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
Press the mode button to return to normal operation.
Dec 06, 2010 | Watches
Change 12 to 24 hr & date
Hi bobwesley,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 17, 2010 | Timex 1440 Nylon watch
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
Hope it helps.
Nov 13, 2010 | Timex 1440 Nylon watch
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 | Watches
How do I switch from 24 hour time to 12 hour time?
Hi greg780,
Hope it helps.
Oct 12, 2009 | Timex 1440 Nylon watch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
Hope it helps.
Oct 09, 2009 | Timex 1440 Nylon watch
How do I change my Casio twin sensor alti thermo watch from 24 hour to 12 hour format?
Oct 09, 2009 | Casio Watches
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Cannot changer from 24 hour to 12 hour
You could change between 12 and 24 hour by pressing the "Mode" button and the "Receive/Start/Stop" button at the same time. I still cannot figure out how to reset for Daylight Savings Time, though.
Watches Logo
418 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
