Computers & Internet Logo
Posted on Jun 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bios update using batch
How can i manually update my BIOS using dos batch file with out OS?
Ekse
Level 3:
  • Master 13,435 Answers
  • Posted on Jun 16, 2008
Ekse
Master
Level 3:
Answers
13435
Questions
82
Helped
3985113
Points
38023
You need the bios update file from your manufacturer and the flashing program that is either included in the package or also avaialbe on the same website, then you basicly need a bootdisk to start up dos and perform the upgrade.
http://www.bootdisk.com/
see the driver free disks for bios flashing.
UPDATING THE BIOS IN AN ADVENT 4489
i answered but lots of questions. most times there is all I have,
NO OS told
dumped PC fails.
it's super old.
the makers is gone, now. (but we learned it is MSI , in sheep's clothing.
The batteries are no good. (bad)
do not run those DOS batch files, you will make it worse , I promise
did the kid tell you to upgrade BIOS on a dead PC, well that is silly as that is RULE #1 do not flash BIOS on any SICK PC. oK???? rule 1 ignored gets you a bricked PC as d this rule,
the PC exact model must match the binary.ROM file and the last update was 2008 !
only the MSI version matters, your OEM is dead.
anything newer will brick the PC as those are all from virus purveyors,, all.
here are the 10 way FLASH and brick any PC.
https://www.techrepublic.com/blog/10-things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/
7 million did ( do not be them)
https://www.google.com/search?q=flashed+my+bios+now+bricked+or+dead&ei=lV1wYbWsO7W3qtsP4ees4A8&ved=0ahUKEwj1yoaAzdnzAhW1m2oFHeEzC_wQ4dUDCA0&oq=flashed+my+bios+now+bricked+or+dead&gs_lcp=Cgdnd3Mtd2l6EAwyBwgAEEcQsAMyBwgAEEcQsAMyBwgAEEcQsAMyBwgAEEcQsAMyBwgAEEcQsAMyBwgAEEcQsAMyBwgAEEcQsAMyBwgAEEcQsANKBAhBGABQAFgAYMslaAFwAngAgAEAiAEAkgEAmAEAyAEIwAEB&sclient=gws-wiz
if the old 500mg DDR2 stick memory fails now, the PC is bricked. (no screens posted of errors)
2answers
Asus motherboard bios recovery
Ekse
Rank:guru_s.gif Guru
Rating: 85%, 1169 votes
In the disk you burned, the bios can't read a zip file, the file needs to be extracted and as far as I remember you need to use a diskette instead of a cd. but I will look into it now.
Comment by Ekse, posted on Aug 07, 2008 Bios warning
Please note, BIOS update is only recommended when experiencing technical difficulties with your system, And is not recommended to be performed regularly.
Moreover, due to the nature of BIOS update, there is certain level of dangers involved. BIOS update must be performed with extreme caution . During BIOS update process, your system must be maintained without interference or power loss to prevent unexpected damage.
In case of BIOS update failure, please follow instructions in your User's Manual for guidelines on BIOS recovery via CrashFree BIOS. In the event that BIOS recovery is not recoverable via CrashFree BIOS, please contact your place of purchase for further assistance on BIOS recovery.
Source Asus
You can get the bios from here
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P4V8X-X
Get the 1008 version
its under Bios and 3rd entry, all os version 1008
File is in zip format, needs to be extracted.
the rom file inside needs to be placed in a diskette.
Comment by Ekse, posted on Aug 07, 2008 Diskette or if you can get the bios to read a cd then that is fine also. Comment by Ekse, posted on Aug 07, 2008 if the setup is looking for a file named as
P4V8X-X.rom
it may be required to rename the PV8XX08.rom to P4V8X-X.rom
But im not perfectly sure what you are trying todo or why it is asking for it. il have to look into this more. Comment by Ekse, posted on Aug 07, 2008 As I suspected, BestDarnGood linked us the manual and the correct page about the problem. it confirms that the file has to be renamed and placed in a floppy.
Thanks BDG
http://www.fixya.com/support/p362915-asus_p4v8x_x_motherboard/manual-11149/page-39
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
I want upgrade bios ga 8simlh rev 1.0,but can not
2answers
How do i chnage bios on dell dimension 4700
start computer with tapping f2 key, you will be directed to bios screen
and there you will get an option to default bios
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
7helpful
3answers
Motherboard
First reboot the computer and enter the bios screen. Disable the bios protect...
Then reboot back into the OS (Presumably windows) and download the bios update from the manufacturer website. It will probably be a zip file containg the bios and the flash utility. Unzip the file and you should have a windows and/or DOS flash utility. If not, the utility should be posted on the website. If the utility is Windows, simpy run the utility. It will ask for the location of your bios file. The update utility will do the rest for you. If the program is DOS, the procedure is similar. Move the utility and bios update into your root directory, reboot, and simpy run the program from the command line.
5helpful
BIOS Update Procedure
All latest Motherboards today, 486/ Pentium / Pentium Pro etc.,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about this.
Please read the following instructions in full before starting a Flash BIOS upgrade: A. Create a Bootable Floppy (in DOS)
•With a non-formatted disk, type the following:
format a:/s
•If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you are flashing the new BIOS.
B. Download the BIOS file
•Download the correct BIOS file by clicking on the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip for Windows 95 shareware/ evaluation copy for that one time use from _www.winzip.com or _www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•You should have extracted two files:
Flash BIOS utility eg: flash7265.exe (for example)
BIOS eg: 6152J900.bin (example)
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file). This information is usually provided.
C. Upgrade the System BIOS
During boot up, write down the old BIOS version because you will need to use it for the BIOS backup file name.
Place the bootable floppy disk containing the BIOS file and the Flash Utility in drive a, and reboot the system in MS-DOS, preferably Version 6.22
•At the A:> prompt, type the corresponding Flash BIOS utility and the BIOS file with its extension.
For example:
flash625 615j900.bin
•From the Flash Memory Writer menu, select "Y" to "Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE: eg: a:13J900.bin
Alternatively select "N" if you don't want to save your current BIOS. Beware, though, that you won't be able to recover from a possible failure.
•Select "Y" to "Are you sure to program?"
•Wait until it displays "Message: Power Off or Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete the procedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
Make sure the new BIOS version has been loaded properly by taking note of the BIOS identifier as the system is rebooting.
For AMI BIOS Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips note: 1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to. (This option is not available when flashing an AMI BIOS).
2. If you have problems installing your new BIOS please check the following:
Have you done a clean boot? In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS.
If you have not used a bootable floppy, insure a clean boot either by
a) pressing F5 during bootup
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by using the EDIT command.
Have you booted up under DOS? Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers. Important: Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above procedure (format a: /s and rebooting from a:).
Have you entered the full file name of the flash utility and the BIOS plus its extension? Do not forget that often you will need to add a drive letter (a:) before flashing the BIOS. Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c: your will need to type a:15j900.bin, rather than 615j900.bin only.
Same toshiba Satellite will not flash problem,,,,,
Hi
Thx for the reply. I think for the meantime we will stict with the BIOS upgrade first. When done then we can sheck out the HDD.
Have you tried the BIOS by Floppy sticking with Toshiba's utility.
The current BIOS v.1.10 is Initial BIOS for Satellite 1800, download ACPI Flash BIOS version 2.10 for Satellite 1800/1805-Sxx4 - http://cdgenp01.csd.toshiba.com/content/support/downloads/1183v21.exe from a Windows PC. Run "1183v21.exe" to extract the files to a folder. Check the readme file for installation info
****Extract from ReadMe File******
A DOS batch file, INSTINFO.BAT is provided in the ZIP archive which will create the BIOS installation diskette.
If all else fails, you can execute the self-extracting diskette image manually. This file is named 1349D21.EXE , and needs a parameter of A: (1349D21 A:) to successfully create the diskette in drive A:
Mike
Grand Canyon Tech
Grand Canyon Tech
