Question about Toshiba Satellite Pro 6000 Notebook
Hdd error when i restore my notbook with system restore on back date. my hdd make clicking sound and hdd not detect.
    Champion:
  • 214 Answers
Hai,
Your hard disk is having some kind of mechanical problem.
Best solution for this is when it boots up, back up your important documents to a pen drive or CD and go for new HDD.
good luck
Rabby
Posted on Jun 16, 2008
Hard disk stop
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 11, 2013 | Toshiba Satellite 2805-S301 Notebook
BIOS Stuck in Elonex 665 Artisan Media Centre
Feb 02, 2013 | Computers & Internet
My computer reproduces files over and over in every library and I can't delete them. Please help this time. I went through a total system overhaul on Feb. 3,2011 and it started the same behavior that...
reproducing files over and over in every library and hard to delete is cause by viruses in your system,your machine is ok only the system is unstable due to that virus and it's not covered by the warranty....hope your restoration point is on so we can set back your system to when it works normally and no viruses..to restore your system to when it works normally..to do this;
Click windows start>pointing all programs>click accessories>system tools>then system restore..
On system restore window tick on "restore my computer to an earlier time"
click next then select date and time to when your computer works good before the error occurs..
click next then next...wait untill the process complete...click ok after finish..but if the problem still persist,go back to steps and select another date..if still nothing,use anti-virus scanning software or reformat hdd if possible..
hope this help, goodluck
Feb 21, 2011 | Toshiba SatelliteM35-S320 (PSM30U7100QV)...
RESTORE SOUND TO MY COMPUTER
hi you just need to restore the system back to the date where sound was working fine , you may follow the process
click on start then go to all programs them accessoris, then system tools select system restore and restore your system back to the date where your system was working fine , (this process if if you have win xp .
for vista and win 7
type system restore in start search and restore the system back to the date.
Hope this resolves the issue .
Sep 16, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
I was just on my ibm t43 and it froze so i manually turned it off now it wont turn back on. it acts like it is going to then it pops up a screen that say an problem has been detected
Hello, Meagan.
Sounds like an operating system problem.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If you can't access System Restore by Safe Mode, try Offline System Restore:
1. Boot from the DVD
2. Select the Language
3. Click on "Repair your Computer" on the Install now screen
4. Click next on the System Recovery Options screen
5. Click on System Restore.
6. Choose the date to which you want to restore
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Apr 19, 2010 | IBM ThinkPad R40 2722 Notebook
Model: U305-7467 Last week my sound card was working. Now, no sound device hardware is detected by OS. Just like a bunch of other user in the internet...
There are 3 solution for this problem.
  1. You should change your sound card slot where it is inserted.
  2. You Can Restore your windows.
  3. You Can Install New Windows.
If the Problem exist you Replace the sound card or have a local tech take a look at the sound card.
Restore Widows
  • 1st Click on Start.
  • Click on All Programs
  • Then click on Accessories
  • Click on System tools Then
  • Click on System Restore.
  • System Restore window appears
  • Then check this option
  • Restore my computer to an earlier time.
  • Click on next
  • Click on date where you want to restore your system then click on next.
  • And the Restore wizard will start.
  • After sometime the computer will restart.
  • After this hope your problem will solve.
Mar 14, 2010 | Toshiba (4CH-VOUT) Sound Card
My windows system has lost the sound device which i have deleted
Go to this page:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=2684&l=en&s=pub&os=WW1&osl=en&catid=&impid=&SystemID=VOS_N_1400
On that page, choose your operating system and then go underneath where it says Audio and download the driver to your desktop. Then run it and that will install the drivers for your sound device.
Dec 19, 2009 | Dell Vostro 1400 Notebook
2 keyboard letters stopped working yesterday after virus was detected? virus went to vault. can we fix it? abcdefg ijkl nopqrstuvwxyz also battery stopped carging too at sae tie, ave disconeected it and...
Hi i'm Rain.
Try doing a System Restore.
  1. Click Start
  2. Click All Preograms.
  3. Click Accessories.
  4. Click System Tools
  5. Click System Restore.
Accept The default setting { Restore My Computer To An Earlier Date.}
Click next . Now select a Date before the problem accured. { Note Go back a month to ensure the problem is resolved. }
If you can not go that far back ,set the date as far back as you can, to make sure the problem is resolved.
Dec 02, 2009 | NEC Versa VX Notebook
Runndll 32 error.how to partition the hard disk
hi,
whenever you repartition a drive all the data is lost in those partitions
a quick way to get rid of rundll32 error is to do a system restore using safe mode, which will restore your system configuration to a date when your system was working fine without rundll32 error, it is possible if you remember the date on which your system was working fine
when the system starts at the blue dell logo start tapping the F8 key and when it gives you the option to use safe mode select it and then
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
here it will show you in bold the dates to which you can restore your system back to, select the date and continue, but restoring a system back in date will make you loose any new settings done to the system or any new software installed to the system.
If you think the above info was helpfull please do rate me
Regards
Ltoso
Jul 07, 2009 | Dell Inspiron 1525 Laptop
NO SOUND ON MY TOSHIBA LAPTOP
You can try a system restore, ie you can take back your computer to a date when it was working fine .
Running system restore in windows Xp:
Start >All Programs> Accessories >System Tools >System restore
Running system restore in Vista
Start> write "system restore in start search bar "> click system restore
If the system restore doesnot work , try uinstalling the sound drivers from the add remove programs and install the new ones from the link below
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-A25-S207/download/page,sh,30994,221,19,.html
Thanks
proton
Jan 10, 2009 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite Pro 6000 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
