Question about Sabrent SBT-UFDB (SBTUFDB) External Floppy Drive
Floppy diskette is stuck in the floppy disk drive. No owner's manual (user guide) shipped with the drive.
2 Suggested Answers
  • 3247 Answers
SOURCE: Did not receive any instructions with the floppy USB external
I would expect that you simply plug the usb cable flat end into the usb port of your computer after Windows has been booted in.
The floppy drive should self install if you are having a current windows xp on your pc. You will see A: drive when you click on My Computer.
Hope this helps. Please rate the solution.
Posted on Jun 16, 2010
Floppy diskette seek failure
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
Windows xp boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps
Sep 24, 2012 | Computers & Internet
I'm looking for a recovery disk for my MSI ms-1013 notebook.
unless you made one or you were provided with an installation disk
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
4. Click Start
hope this helps you
Oct 19, 2011 | Computers & Internet
"Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
Floppy is stuck in slot
The most comprehensive information that I have found is located at Computerhope.com
Floppy diskette stuck in floppy drive
http://www.computerhope.com/issues/ch000828.htm
If the above does not work then you will need to replace the floppy drive and take apart the old floppy drive to remove the disk.
May 11, 2009 | Computers & Internet
Nexxtech usb external floppy won't eject
Look for a very small round hole in the plastic "cabinet" near the media slot (on one side) and gently poke a small paper clip (unbent, of course, first) in to manually eject the disk.
Feb 24, 2009 | NexxTech USB External Floppy Drive (NEFD2)...
Metal sleeve
3.5" FLOPPY DISKETTE
Below we have represented a picture of the now commonly used 3.5" floppy diskettes. The below representation is what the back of a floppy diskette looks like. As you can see there are four main visible parts:
floppyd.gif First, the top left of the back of the floppy there is a small tab. This tab enables the floppy disk to be switched from write protected and un-write protected. Move the tab to the top position, creating a hole, makes the disk write protected. This means that nothing can be written, erased or deleted from the diskette. Moving the tab to the bottom position allows the disk to be un-write protected, which means the diskette can be written too, erased, and or have information deleted from the diskette. Some diskettes, which are generally cheaper diskettes, will be missing this tab. To write information to the diskette you will have to place a piece of scotch tape over the hole.
Second, the top right hand of the back of the floppy you will notice a small hole. This tells the computer if the diskette within the computer is a High Density diskette.
Third, you will notice the circular metal disk in the middle of the floppy diskette. This is used to rotate the magnetic medium within the floppy disk casing.
Fourth, you will see a metal door which can be moved left and then will snap back to its original position. This door is used to allow the read/write head within the floppy drive to have the capability of accessing the magnetic medium within the casing. Once the diskette is removed, this door will snap back into position, helping to prevent anything from getting on the magnetic medium and destroying it.
5 1/4" FLOPPY DISKETTE
Below is a representation of a 5 1/4" floppy commonly used in 1980's and is generally no longer used today. The 5 1/4" floppy diskette was really floppy (flimsy) when compared to the 3.5" floppy diskette.
floppyd3.gif As you can notice in the above illustration, the 5 1/4" floppy does not have many involved components. First, you will notice the Write protection tab which would be present if the diskette allowed information to be written to it. Placing a piece of tape over the hole or if the hole was not present would make the diskette write protected.
Second, you should notice the large hole in the center of the floppy diskette. This hole allowed the platter within the floppy to be rotated allowing the information to be read from the write access hole.
Third, you should notice the Index hole, this hole was the computer's way of knowing where the starting point of the sector was on the diskette by physically having a hole punched in the film disc within the plastic casing.
Finally, you should notice the write access hole. This is the location which information would be read from as the disc within would rotate. However, because there was no protection like that found on the 3.5" floppy diskette, the 5 1/4" floppy diskette was generally protected by placing it within a protective sleeve.
Hope this helps ya/Let us know ,ok Thank you for using fixya.com.Please dont for get to Vote.
Jul 20, 2008 | Dell Inspiron 6400 Notebook
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
The Z1D CITIZEN floppy drive on this computer cannot read disks. When you put a disk into the drive, it constantly returns a dialog message in windows asking to format the drive - and cannot read any of...
some floppy can read and some floppy cant read
it means that ur floppy drive reads the information which they originally save it from citizen floppy drives. Floppy drives like citizen if u use in any place u can use the citizen floppy drive any where
Feb 15, 2008 | Citizen 1.44MB 3.5-Inch Floppy Disk Drive...
Sabrent SBT-UFDB (SBTUFDB) External Floppy Drive Logo
104 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
Colin Stickland
Colin Stickland
Steve
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
