Question about HP LaserJet 3300 All-In-One Printer
Hp laserjet 3300
Black dots all over the page when printing
    Genius:
  • 1,142 Answers
My hp jaserjet 1150 when hitted than printing quality too bad & Black spots on the paper.............
First take half test page. see what about the page if same dots appear replace toner cartridge, the black not come replace the teflon sleeve
Nov 05, 2013 | HP LaserJet 1150 Printer
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
Hi, I have HP LaserJet 1020 and few days ago three tiny black dots appeared on the left side of the printed pages, just by the border. The borders apper at regular intervals. I found somewhere that it...
dots printed are from the cartridge, you proved that with the change to the old one. If the fuser was faulty, it would repeat the dot 2.5 times down an 8.5 x 11 page
Replace the cartridge and please use HP , remanufactured cartridges fail prematurley and usually wind up costnig more in service and repair/exchanges.
Jan 15, 2011 | HP LaserJet 1020 Printer
HP LJ 2600 "dirty" printing
If the toner cartridges are "refills" that might explain some of your print quality issues. Unfortunately, HP only has 2 replacement parts for that model, the fuser and the ETB (Transfer belt) both would require a technician to replace. Check the transfer belt of any tears or punctures. Careful not to touch it, oils from your skin can cause quality issues as well. If at all possible replace all the toners with ones that were working fine.
Jul 31, 2009 | HP Color LaserJet 2600n Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
Hp2600n printing black dots centre page
Could be a dirty fuser, try a laser printer cleaning sheet.
This is more of a problem if you use (some types of) remanufactured toner cartridges.
Feb 04, 2009 | HP Color LaserJet 2600n Printer
HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
Dec 31, 2007 | HP LaserJet 1320 Printer
HP LaserJet 3300 All-In-One Printer Logo
142 people viewed this question
Ben Johnson
