Question about Microwave Ovens
I need the instructions for a k-mart home essentials grill. k-mart code:688282 and vendor model AHG-1050
I need a instruction manual for a Delonnghi touch control microwave oven with grill model No.DMX 30
http://www.delonghi.com/en-gb/customer-experience/instruction-manuals
either go here and use the product code bar on the label on the back
or send an email to the customer support
they will email you the manual
i cant see it onlne...
Dec 10, 2014 | DeLonghi Microwave Ovens
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
Hi i have a george forman grilling machine GR10ABWG model number 10198 ,and i am looking for operating instructions and recipes,can you help,thanks very much
HELLO.
solution below.
The best place to get the GRILLING MACHINE manual guide is to visit the manufacturer website to order for the manual stating the GRILLING MACHINE model number and give our house detailed address.
However GRILLING MACHINE manual guide can also be purchase at any GRILLING MACHINE authorized dealers around your local area with the model number for compactibility(easy use).
Thanks.
Sep 20, 2011 | Microwave Ovens
I need the lower rubber on my 1050 foodsaver. Any ideas
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Jan 06, 2011 | Microwave Ovens
How to replace light bulb in Quasar microwave oven model MQS1236H
Could that be MQS1263H?
Either way, this owner's manual may be close enough.
If it's not addressed in the manual, and there's no obvious cover on the side or back, then you'll have to remove the cover of the oven to change it.
If it's an owner the range type, you can likely get to and replace the light by just removing the grille or possibly the control panel assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's a counter top unit, you will need to remove the outer cover and look for it near the magnetron cooling duct on the right side.
Before doing any disassembly, please see these files: safety disassembly.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
You can also order Panasonic parts here.
Dec 25, 2009 | Microwave Ovens
Changing microwave light bulb
Check the owner's manual to see if yours is a model which allows access to the lights without pulling it down from the wall.
Accessing the lights on some models will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Many use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can find handy exploded views and order parts by model number here.
Oct 06, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Feb 04, 2009 | GE JVM1750SMSS Microwave Oven
Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sanyo Super micowave & grill. Change the light bulb which is U/S Dennis Mann
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter to model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Sep 05, 2008 | Sanyo Microwave Ovens
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
