Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
How do I change the gas line? - Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
  • 7,733 Answers
Cranking but not starting until second try.gas smell.Gas line replaced.Had spark plugs, fuel filter changed.Still having starting issues and today noticed leakage near gas tank.
Gas line was only repaired, not replaced. I don't repair gas lines because of this problem. The entire line is replaced, both of them, supply and return. From the tank to the injector rail. This is the reason for the long start. Loose of fuel pressure.
Aug 07, 2016 | 2002 Subaru Outback
Gas line unplug
many things a puddle on tank maybe the unplugged line that if put cap on end the smell will disapear but check your filters along chassis lines bad plastic clips need a change every now and then
Nov 09, 2013 | 2000 Mazda Protege
I changed all the gas lines in the chainsaw. It has spark and gas but will not start up. Prior to changing the gas lines it was running but when it would run it would shut off and not start back up. We...
I think before you do too much more you need to check it is mechanically sound, remoce the muffler and check the condition of the piston through the exhaust port, any damage and it will never run right.
Jun 17, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to change fuel filter
ITS ON THE NEETH THE CXAR JUST FALLOW THE GAS LINE WHEN YOU SEE THE GAS FILTER LOOSE THE SCREW IN THE GAS LINE ITS A CLIP WICH HOLD THE LINE IN PLACE PULL THE CLIPS AND PULL THE GAS LINE OUT.
May 19, 2011 | 2002 Audi A6
Frozen gas lines
POUR SEAFOAM IN GAS TANK.IT WILL DRY OUT MOISTURE IN GAS.YOU NEED CHANGE UP ON GAS STATION.BUY GOOD BRAND GAS.WHEN GAS LINE FREEZE GAS FULL OF WATER.
Jan 24, 2011 | 2000 Buick LeSabre
Just changed gas bottle, for our gas fire, now cannot get to ignite
When you open the gas line to change the tank you let air in the line very common problem just take the line loose at the gas fire and bleed the air out. If it has auto ignition just let it cycle it will bleed out the air after a few try's.
hope this helps.........
Dec 07, 2010 | Heating & Cooling
HOW DO I CHANGE A FUEL FILTER ON MY 2006 TAURUS?
Gas filter located Under back right side of car just under the right rear door. Should only take about 10 to 20 mintues to change out.
2 Types
1. One has 2 plastic clips that can be pulled out and gas line slides off. Then unscrew worm clamp (radiator clamp) pull filter out and put new one in make sure the arrow is pointing to motor.
2. The second has what are, or some call line connect which you will need a gas line separator tool. Any parts store will have it cost, about $7.00 - $10.00 for the set. Slide the right one around the gas line and push All the way in at the same time pull the gas line until it slides off the filter. Reinstall filter and push the lines on until the click.
Feb 19, 2010 | 2006 Ford Taurus
How to remove gas line from the gas filter.
the gas line connectors require a special tool sold at autoparts stores
the tool wraps around the gas line and removes the locks
Apr 25, 2009 | 1999 Ford Econoline
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
53 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
