Question about Garmin iQue 3600 GPS Receiver
I haven't used my Garmin ique 3600 in a few years. What do I need to do to get it operational again? a) If new battery ... how do you install it? b) I need "long" hand-held battery life. Ideas? c) I think the cradle or the hand-held's pins might be loose/bad. Ideas? Thank you. James
  • Garmin Master
  • 6,993 Answers
since you haven't used your Garmin ique 3600 for a long time, then you will needing a new battery because the battery on it must have been flat and dead.
You can order for a replacement battery at batteryship.com
To install a Garmin iQue 3600 battery follow these installation instructions below:
Begin by backing up all your data...then proceed with the following:
1. Remove the four screws in the back of the case and set them aside. The top two screws can be accessed by flipping up the square piece at the top of the back of the device. Our tool kit includes 2 Torx screwdrivers. The larger T6 Torx screwdriver should be used to remove standard screws. If it is not the correct size for the screws in your device, please let us know. If the screws seem smaller than the T6 screwdriver, try the T5 Torx instead. Set the screws aside for reassembly.
2. Use the green pry tool to pry around the case. Remove the front of the case very carefully once it has been unsnapped from the rest of the device, and set it aside.
3. Using the included Phillips screwdriver, unscrew the two screws that hold the motherboard into the back case. One is at the top right of the device and the other is at the bottom left. Set the screws aside for reassembly.
4. Flip the motherboard and screen open to the left (as if opening a book), keeping in mind that the motherboard will remain attached to the back cover at the top left. This will give you access to the battery.
5. Unplug the battery connector for the original battery from its socket, taking care not to damage the socket. Remove the original battery (carefully prying it out if needed), making sure to notice how the battery was oriented. Be very careful not to puncture or damage the battery when you remove it.
6. Plug the new battery's connector into the socket. Do not force it- it will only fit in if oriented correctly. Note the location of the prongs in the socket and the plugs on the battery to find the correct orientation.
7. Place the new battery (oriented correctly) into the battery compartment.
8. Replace the motherboard and re-install the two screws that hold it in.
9. Replace the front cover and re-install the four back screws.
10. Charge the new battery for at least 3-4 hours.
****PLEASE NOTE: Patience and care, along with moderate technical and hand tool ability, are required for the successful replacement of a battery. Excessive force may result in damage to your device. The instructions above come with no warranty or guarantee. By utilizing these instructions, you agree to hold Batteryship.com and BatteryEducation.com blameless and unaccountable for any and all damages, problems, or personal injuries that may or may not arise by your use of these instructions. Replacing your battery may void any warranty you have on your device. Please read all instructions BEFORE replacing the battery.
As for the hand held pin, you can fix it back in the process of the battery replacement.
Good luck.
Posted on Nov 08, 2010
I have a Garmin iQue 3600, I was changing the battery, when opened the unit the switch marked rec esc on the side of the unit flew apart.I need a diagram of how to reassemble it. Thank You
iQue 3600 Undo engl.V.6 Release
Hallo -
I mistakenly IQUE3600 my system 5 at the english version 6 updated, now I have a white screen,
there's nothing more.
Please help
If your IQUE -Problem is not reparabel - I would sale it, for repair my
If your Garmin is beyond repair, I would rate this unit as a spare part for my broken
Buy
Wenn dein Garmin ist unreparierbar, ich würde dieses Gerät als Ersatzteil für mein kaputtes
kaufen
Oct 26, 2010 | Garmin iQue 3600 GPS Receiver
IQue 3600 won't synch with new laptop with Vista
As far as I know there are no iQue USB drivers that work for 64-bit Windows. I have Windows 7 Ultimate 64-bit and my iQue is not recognized. No solution so far! I use my XP machine to synch.
Sep 29, 2009 | Garmin iQue 3600 GPS Receiver
Screen replacement for GarminiQue 3600
I have a 3600 that worked perfectly until i hit the "UPDATER" icon at Garmins suggestion, it fried something but the screen and the rest of the unit are in great shape........ I could not shut the unit off so I took the batter out, the screen is fine, if anyone want it for 40 bucks, drop me a line......... Sammmyg96@aol.com
Nov 04, 2008 | Garmin iQue 3600 GPS Receiver
Need a new Battery Installed
I purchased a new battery with the tools to replace the old battery. It is a piece of cake. I think I paid $ 15 for the battery/tools and that was shipped to my home. If you're still in need of help. Let me know.
Sep 02, 2008 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600
Sounds like a battery problem and I ordered a new battery to see if that will fix the unit.
We will see!
A Sudia
Aug 26, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600 does not work why?
Well unfortunately, sounds like it's replacement time.... same problem I had with mine. Even with an external antenna...no or little signal. Garmin charges $200 canadian for an exchange unit.
So much for costumer support.
Good luck.
Apr 28, 2008 | Garmin iQue 3600 GPS Receiver
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
Did you try to do ANOTHER hard reset?
Aug 13, 2007 | Garmin iQue 3600 GPS Receiver
Unit will not charge, changed battery but still does not work... Help
Sound as though you shorted something on the main board when you installed the new battery. Just sell the unit for parts on Ebay
May 03, 2007 | Garmin iQue 3600 GPS Receiver
GPS receiver problem
Does it work with an external antenna hooked up? If it does, it could be a problem with the flip-up internal antenna.
Mar 12, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
43 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
