Question about Poulan Garden
Needmanuel to chabge spark plud and stater rope for weed eater fl1500le
    President:
  • Poulan Master
  • 1,545 Answers
See page 7 of your manual here. You will need Adobe Reader installed on your computer to view this as it is a PDF file.
http://dl.owneriq.net/2/2df8a700-4f65-4a17-82fd-8cd7ee160322.pdf
The starter rope removal is a repair and is NOT included in the manual. Here are the repair instructions.
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers
Posted on Nov 08, 2010
Weed-eater fl1500le new carb new gas and filter new spark plug getting spark will not start
try priming it 10 times and hold the throttle wide open when trying to start it
Jun 15, 2017 | Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Weed eater featherlight XT260 rope pully
    Your recoil could be messed up if you cant pull the rope out or if its just too hard to pull out you could have it too tight.
    Jul 29, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
    you may have wound the spring backwards, try winding the othe way.
    May 09, 2010 | Garden
    How to repair spring starter on FL1500LE
    The casing is situated so the spring faces the starting spool. The spool is plastic and the rope is wound around it. The hook goes to the spool. Put it back together carefully! Good luck...Lee
    Nov 24, 2009 | Poulan Featherlite Gas Blower, with Low...
    Can't get weed eater started. Have an older weed eater brand. Fuel is getting to engine, but can't get it to start. How do I adjust the carb to get it to start. I have cleaned everything out and have the...
    This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
    Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
    Sep 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    Cant pull the rope but when you take the spark plug out the rope will pull
    Sure its the correct spark plug? Sounds like the piston is coming in contact with the spark plug.
    Aug 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Garden Logo
    69 people viewed this question
    Top Poulan Garden Experts
    Jim Parker
    Jim Parker
    roeb
    Jay Finke
    Jay Finke
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
