Question about Exercise & Fitness
The belt on my dynamix treadmill slips to one side after about 1 minute of running/2 minutes of walking every time i use it. if i tighten it it slips to the other side and so on, at the moment i just start, have to get off reset the belt, start again get off etc. any help?? i have no idea about this kind of stuff so any help is muchly appreciated!!!!! thankyou!
  • 95 Answers
SOURCE: i tighten the screws behind the belt but it still slips as i walk
Sounds like the motor drive belt is slipping,remove the motor cover,be careful some models have hidden screws in recessed areas underneath if you remove the correct ones the hood comes off easily. There is a bracket that has a bolt to adjust the motor belt tension.Also if you tightened the walk belt up it may be too tight which could cause it to wear or tear easier,the rule of thumb is tighten the walk belt just tight enough so it doesn't slip.
Posted on Aug 12, 2009
SOURCE: how do I tighten the belt on my york t275 motorised treadmill?
http://www.yorkfitness.com/store/PDF/T275-INS_MANUAL_022005.pdf
Posted on Jul 30, 2009
  • 43 Answers
SOURCE: image 15 r treadmill belt is slipping. can I
that can be tightned up,pretty easy to do-just don't over tightn, want to be able to push down on belt 1/4th to 1/2 inch
Posted on Jan 08, 2010
Testimonial: "Thanks for the help. Much appreciated! "
SOURCE: belt is slipping on a proform 740cs treadmill.
Similar solution on a ProForm 500i. Symptom was that the belt would slip whenever you'd step down.
Solution was to use an Allen wrench to tighten the bolts at the back (behind) of the running deck. Had to go two full turns. Careful to unplug first, and careful to tighten each exactly the same amount.
Also wiped the parts of the platform I could reach under the belt with vinegar water, since they were gunky.
These two things fixed the problem
Posted on Feb 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Posted on Mar 02, 2010
How to adjust the running belt??
Check page 27 in the owner's manual:
"If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD. Using
the allen wrench, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly tightened,
you should be able to lift each side of the walking
belt 3 to 4 inches off the walking platform. Be
careful to keep the walking belt centered. Plug in the
power cord, insert the key, and carefully walk on the
treadmill for a few minutes. Repeat until the walking
belt is properly tightened."
Dec 18, 2010 | Nordic Track NordicTrack Treadmill, A2550
Belt is slipping,
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill running belt adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
Jul 06, 2010 | Life Fitness 9000 Next Generation...
How do adjust tension on treadmill belt
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 27, 2010 | Exercise & Fitness
My belt needs to be adjusted. I believe it needs ...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift the edges of the walking belt (2 to 3 in.) off the walking platform. Be careful to keep the walking belt centred. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 20, 2010 | Lamar L-1300 Treadmill by Star Trac - !
Belt is slipping when i walk on it
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 17, 2010 | Icon Image 17.5 S Treadmill
Belt is slipping
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 15, 2010 | RTO Image 15.0R Treadmill Walking Belt
My walking belt is off cener
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
May 07, 2010 | Proform 530 Treadmill Walking Belt
Treadmill belt keeps slidding to the side
Apr 08, 2010 | RTO Image 15.0R Treadmill Walking Belt
The belt went all the way to the right side and it sticks when walking
Mar 10, 2010 | Proform 650 Crosstrainer Treadmill
Adjusting the walking belt
Jan 13, 2009 | Exercise & Fitness
Exercise & Fitness Logo
159 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
